If you meant that you are changing the INDASH set with another model, the wiring harness will not match unless it the same model/make.
Now it is possible to source the harness which fits to some model but other wise you might need to manually STRIP the wires on the harness and connect from the given wires . Since all the connections are available it is only important that the leads are tested to be connected, the +B switched, + continuous, the Ground and then the speakers, front and rear. If amp is used then connected the switched power to the amp.
