Question about Kingston Combo 4GB DTI USB and 4GB (KWB164G3CQ) Media
I got Kingston DTI/64GB, when I insert in my PC - having windows XP- it shows message for FORMAT - I click on OK button, Format window opens - Capacity shows 62.4GB, System = nill, when clicking on OK, nothing happens -It shows "0 Bytes" in Properties window. File system show RAW. Now what? Please, help me. What can I do to use?
  • Kingston Master
  • 18,060 Answers
Try to format it in the camera,
Posted on Nov 13, 2017
    Master:
  • 231 Answers
Open lock to enable.
3 Suggested Answers
SOURCE:
  • 33 Answers
SOURCE: Files in my kingston pendrive does not open up
Hi manoj_clc,
The "other PC" needs to have the same application installed that created the files. It sounds likely that is the problem for the other PC. If the files are failing to open using the PC that originally copied the files, then try formatting the USB drive (formatting deletes all data). Before you copy the file again, make sure the same file opens from your computer prior to copying it. Now copy the file to it the USB drive again.
Kingston Tech Support
Posted on May 06, 2009
rajeshpait
  • 542 Answers
SOURCE: problem with 4gb dti pen drive
Try to format the pen drive may solve your problem. Also chkdsk command to solve most of the problems.
Posted on Dec 14, 2009
Flash drives says when it open that needs to format first before it used?
it because there are a a logical eror
just format it but you will lose all data
to format (on windows 2000/XP) right-click on the key icon and click on "Format" then a litle windows apair on t press "Format" bouton
Oct 27, 2012 | Kingston Data Traveler 2 GB USB Drive...
I got Kingston DTI/64GB, when I insert in my PC - having windows XP- message occurs for FORMAT - I click on OK button, Format window open - Capacity shows 62.4GB, System= Nill, I select Quick format option...
first try to format in command line
Start
go to RUN
Type CMD and press enter key
in command window type format H:/fs:FAT (H: stand for my Pen Drive name change it if you have different)
press enter key
yes to all message appear
now you formatting start
if not so try this: 1000% work
download any low level formatting system and format from that or you need 3rd party formating tools like HP format tool to format RAW to FAT,
if still not work it mean your PEN Drive got Damaged and you have to purchase a new one.
Do vote me if this help you.
Jul 27, 2011 | Computers & Internet
My Kingston Data traveler 2 GB/DTI wil not open once insert into laptop. Then a window pops up to say I must format dixk. When I hit format the disk will not format.
is the operating system widows 7
take it to another computer insert 2 GB USB click start control panel administrive tools computer management disc management you can defragment this USB drive or you can right click select properties tools check now tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files or tick in one box then return after it has fixed the first task then tick the other box then take plug it into your laptop and try again
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Mar 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
- Click permissions
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a DTI/64GB Kingston DataTraveler flash drive. i try transfer document from my flash drive but it read: it is write-protected: is there anyone could help to remove the write protected. i wil be...
also
- Click permissions
hope this helps
don
Feb 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to format Kingston 64GB Data Traveler 101
insert your kingston 64GB drive
click start right click on my computer select open you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Jan 30, 2011 | Computers & Internet
How to format 64gb kingston
You can simply right click on its drive letter in My Computer and select format. Note that if your windows is installed on it, you will need to reboot while having a windows cd inserted, and you will be able to format at the Windows installation prompt.
Dec 17, 2010 | Computers & Internet
My datatraveler 64gb dont formating in my
datatraveler dti.4gb ""the disk in drive E is not formatted" how to solve my problem
Dec 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Combo 4GB DTI USB and 4GB (KWB164G3CQ) Media Logo
437 people viewed this question
Top Kingston Electronics - Others Experts
WTF Chuck.....
WTF Chuck.....
Håkan Sterner
SANDIP MISTRY
SANDIP MISTRY
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
