Question about Black & Decker String Trimmer Cordless 12" 18V
Black and decker cordless grass hog CST 1000
Where can I buy the orance cover that holds in the spool and plastic wire, mine broke
  • 163 Answers
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
How to change the spool in the black and decker grasshog
Is this the cordless Grass Hog? Turn the trimmer upside down so you're looking at the bottom. There are two orange tabs on either side of the spool -- push these in and the head should pop up so you can pull it out.
On the new spool, feed the cord out several inches and stick it through the hole in the trimmer where the old cord stuck out. Then pop the spool into the cavity so that the orange cover faces out (toward you). Pull the cord taut and make sure it is not long enough to hit the plastic guard. If it is too long and it touches the guard, pull the spool off and wind the cord in a little bit. If the cord is too short, pull the spool off and thread out a little bit more length and try again.
Turn the trimmer right side up and turn it on to make sure it works. If you hear a loud rapid thumping sound that sounds sort of like a machine gun, the cord is too long and is hitting the plastic guard.
Jul 04, 2010 | Black & Decker 14" Grass Hog Xp...
How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Jun 01, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Weed whacker
I was unable to get that ring off also... I was able to pull plastic side apart far enough to pull motor out and "rewire" it. Even fit back in when I was done... just barely. and was very gentle...
I do not know how to get the ring apart, though.
Feb 01, 2009 | Black & Decker Cst2000 12 - Volt Cordless...
Weedwacker wont turn off
We have a Black and Decker CST 1000 and other than the convenience of no cord, it constantly has problems. Won't hold a charge, spool holder cap broke and we can't find the part, handle cracked and finally broke. We have a black and decker blower and it won't turn off either. Fortunately it's corded so we can just unplug it. No more Black and Decker for us.
Jun 05, 2007 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
143 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
