Question about RCA RCU300WBL Remote Control
Remote not working
I have an rca universal remote works fine for the vcr used to work for tv then only worked sometimes now wont work at all i tried reprogramming with evry code still only works for vcr please help
  • Anonymous Sep 24, 2008
    disney electronics tv
  • 4 Answers
I just found this website -
http://remotefinder.rca.com/default.aspx?site=rca
See if that gives you the right code...
Posted on Sep 28, 2008
The codes i got with my RCA universal remote wont work...
Sometimes the programming procedure might haven't right. Four digit codes to check with RCA Brand TVs are: 0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you want to know more, check this.
Dec 28, 2012 | Televison & Video
Remote menu button not working
Sometimes you can enter a code that will work nearly all the buttons, but is not the correct code for your DVD player. You should try other codes. But sometimes a universal remote will NOT work every function.
Dec 22, 2012 | Toshiba SD-V392 DVD Player/VCR
I was wondering some codes for a RCA tv/ vcr combo
have a old rca television with a build in vcr. connectec a cable box remote works only for volume and channel but power button does not work, with remote was set and stop working call cable company and was told to contact rca to recieve codes for television
Sep 30, 2009 | Philips Universal PH301S Remote Control
Cant get my universal remote to work my Zenith model TVBR1922
ha i can help a little ,i also have a rca universal and same tv,vcr combo,the codes in the list rca provides
do not work ,but if you go through the code search procedure componet vcr,until the set turns off
hit enter,this will allow for power on off funtions and ch up down or number keys,also vcr functions,
but no vol, control or menu nevigation,hope this helps a little
Jan 08, 2009 | Zenith TVBR1922 19 in. Combo
Switching to play video games--how do I do it?
You are going to have to order a origanal remote that came with the TV to do this because the universal remote does not have the game mode feature! Go to www.remotes.com to order yours!
Please rate my answer and help keep this site FREE!
Thank You!
Jan 02, 2009 | RCA Universal Remote Control
I LOST MY REMOTE TO MY DVD/VCR COMBO AND I BEEN TRYING TO PROGRAM A UNIVERSAL REMOTE BUT IT WONT WORK
"Universal" is a joke; they should be called 'multibrand.'
Although their prices are sometimes stiff, they normally have originals for sale:
Remotes
Dec 06, 2008 | RCA DRC6355N DVD Player/VCR
Rca universal remote code
You can go www.rca.com and locate a code in there universal code section . they have a link for this . If you can not find it let me know what rca remote you have. The remote # is generally on the front or on the battery door cover . I will see if i can find it for you . Also is this just a tv or is it a combo unit? If it is a combo also get the codes for a DVD or VCR if it has one of these built in your tv . Sometimes you have to use the codes for dvd or the vcr . Let me know , thanks
Mar 09, 2008 | Broksonic CTGV-5463TCT TV
VCR stuck on menu screen
Thank you. I did fix the problem. Reviewed the instruction manual for the Samsung VCR and removed the SAFE reading on the VCR by just holding down the TV-VCR button on the RCA universal remote for several seconds which then released the frozen menu screen. From there I was able to reprogram the TV using the instructions and codes for the RCA universal remote. I still have to reprogram the VCR.
Mar 09, 2008 | RCA Universal Remote Control
Diamond Vision TV/Remote
SOLUTION: I had the same problem with a Diamondvision DTV3913. After trying many universal remote controls, I found one that worked. The RCA universal remote CRCR3273 / CRCR3373 (also referred to as RCR3273 / RCR3373) was the answer. It has 3 codes (1232, 1233,1234) for DiamondVision TVs and the first one worked. It gives me all the control I needed including the hard to get ones like input selection, main setup menu etc. It also has codes for DiamondVision DVD players and VCRs. I see it at BestBuy for $8.
Jan 10, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Set up with daytron TV
Have you tried hooking up the VCr and TV using RCA cables? You must connect Video out from VCR to Video IN of Tv and Audio out of VCR to Audio IN of TV.
Jun 01, 2007 | RCA VR546 S-VHS VCR
RCA RCU300WBL Remote Control Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
