Question about Sport & Outdoor - Others
Engine runs rough when we throttle up
We have a 40hp 2 stroke Yamaha engine on our boat. It ran great then it started to run rough when we would increase the throttle. It was intermittent at first, now it is all the time. We changed the plugs, new gas filter,carburtor was taken off cleaned and adjusted . It worked great for about 20 minutes then we shut down and anchored. When we were off on our way again it started all over. Could this be an electrical problem.
Please help,
Mike
  • 10 Answers
Sounds like a spark plug issue. If the spark plug is not torqued after a good number of months it can seep at high rev sustained pressure. Otherwise I would look at the spark compensator or possibly the float.
Posted on Jan 02, 2010
    New Friend:
  • 41 Answers
Hello, It could be ele. If you have ran cheap fuel in it and it has sit for a while, I would clean gas tank,lines, carb again, and run prem gas in tank.
Posted on Nov 25, 2008
I have a 40hp yamaha outboard it starts great but when i put in gear it stops
If it's a 2-stroke, have those carbs cleaned...
Then check if he runs on all 3 cylinders.
Aug 11, 2017 | Yamaha Boating
Jerking outboard engine
Good Day Khairul,
Are the Carbs Synchronized To Open And Shut At The Same Time?
If This Is Correct ! Then Do You Need To Pump The Primer To Contine Running?
If Yes Then Replace Fuel Pump DiaPhram
It Coud Still Be An Electrical Fault,
Coil,Trigger Or Stator .
Check To See Condition Of Plugs After Running,
Hope This Helps
Regards
Gordon
Sep 10, 2013 | Boating
Free Mercury Outboard ONLY, 2-40HP 1965-1989 Repair Manual 1-2 Cylinder, 2 Stroke
I have a problem with my 2 stroke 20hp mercury 1989,when I run 10-90% throttle it's works fine but when in 100% its only runs in 90% and doesn't sound normal like it's not burning right.
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
I have a 1997 Yamaha 40hp....C40PLRV without oil injection. My Sealoc manual calls for a 100:1 fuel mix. I had a dealer tell me to run 50:1, but it idles rough and is hard starting when cold even with...
Mate.2 stroke motors WITH oil injection run between 100/1 and down to 40/1(rich).With yours being pre-mix,it should run at 50/1 to be safe.Using a good quality 2stroke oil,with low smoke,it should run well.The only thing that may change, is how you use the motor.Slow trolling or running along travelling.A spark plug that is 1 heat range hotter will help burn the fuel/oil mixture if you do a lot of slow running.Faster and /or high speed running,will keep your plugs ok.These are safe guides not to cook up a piston.Hope this helps you
Dec 06, 2010 | Boating
Yamaha 50 hp motor oil red and green oil sensor lights are on
The engine will self destruct if you continue to run it without the proper oil mixture. Some oil systems have to purged of air if ran dry. Seek professional assisstance.
Aug 21, 2009 | Bass Pro Boating
Engine cuts out while running
Sounds like a coil pack getting hot and breaking down
Aug 07, 2009 | Boating
4 stroke Yamaha 50HP -Runs rough at all throttle levels
If it has the old points system you will need to set the points also adjust the carburatior screw the screws all the way in and back out 2 1/2 turns then get it to run turn the air mixture screws till it runs smooth. you want it slightly lean then enrichen it slightly, afterword shut the engine down and look at the plugs if they are gray black they are ok. good luck.
Jul 09, 2009 | RTO Oar Sockets
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
Sport & Outdoor - Others Logo
339 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
