Question about Teac Audio Players & Recorders
Set to box problem
Hi and thanks for taking the time to read this....
I have a TEAC DVB820 HD set top box,and until yesterday it worked fine. We had a power failure yesterday afternoon and now when i turn the box on it just says 'boot' and wont let me search for channels or access menu. I have left it off (unplugged) over night and let it stand, when on,and still i cant get past the 'boot' on the front display.
Anything you can offer to help me will be greatly appreciated
Tracy
  • 2 more comments
  • Nuffa Sep 01, 2008
    I fixed the problem by downloading the firmware and putting on a USB stick,then into the back of the unit. :)
  • Vooney Feb 27, 2009
    G'day, I have a similar problem. Where can I get the firmware from.
    Cheers Matt
  • Nuffa Mar 09, 2009
    Now i have a new problem (teach me for rearranging my loungeroom) when i turn the unit on i get c100 message...iturned the unit off at the power and held in the on/off button,and turned power back on.Now all it says it boot....and has done for the last 10 hrs.I've tried turning it on and off,at the power and with the remote but too no avail.
    Please any help or information greatly appreciated.
Where did you grab the firmware for it? I can't find it anywhere!
Posted on Sep 01, 2008
I have Philips 15PF9945 (15"
If the last problem happened at first, I would blame the power supply since this is a very common point of failure. You have had so many different problems preceding it dying completely, it sounds you should plan on replacing the main board and the power supply. The failures you first had all point to the main board where most of the signal activity processes happen but the fact that it will not even light off now point to what I would call a 'lemon.' If the set is more than 2-3 years old, it may have still been built by Philips but all the newer sets under that name are now built by Funai, the worst Asian manufacturer of all.
Apr 18, 2011 | Philips 15PF9945 15 in. HDTV-Ready LCD...
My buffalo external hard disk can not read since yesterday, I/O device error. previoous was working fine. Do not know why? my Buffalo external hard disk model :HD-PX320U2
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Apr 13, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Tape insertion problem
Now It needs mechanical adjustment, and your camera work fine again.
Thanks
Mar 03, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Failed tv reception after about an hour????
Witout knowing your set up I can only guess at the set top box getting hot and failing.
Is the Teac box well ventillated? If not, put it somewhere where it can get cool air (ie not enclosed in a TV cabinet for instance).
I doubt it's your antenna if it works for a while, but you maty want to have your coax connection checked out. If you use a booster, that may be failing.
Sorry I can't be of any further use.
Jan 13, 2010 | Televison & Video
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Aug 24, 2009 | Televison & Video
Connet Hd set top box
May 31, 2009
Born to Race,
I have just bought a TEAC HBD841 which was on discounted sale at a local Electrical Store
Besides not being able to figure out how to connect the device to my elderly TV because the inadequate instruction booklet that is written in a language an Electrical Engineer would have difficulty understanding - does not explain which plugs go where, (try plugging a three plug lead into a 2 plug TV) but since then I have found out that the HDB841 has been withdrawn from sale and is no longer available.
No wonder it was cheap!
I suggest you get rid of it - quick
GB
Apr 20, 2009 | Televison & Video
DVB820 set top box error message
check C14, C15 and 278R33 (3.3V supply. cheers
Mar 10, 2009 | Televison & Video
I have lost 1/2 my instruction book ie the code part
manuals and codes for the One For All remotes are at this link http://www.oneforall-na.com/
Please take the time to give this solution a fix ya rating.
clarkco
Mar 05, 2009 | One For All URC-3300 Remote Control
Worked yesterday / not working today
Someone else figured this out, but I've seen a lot of people with the same problem. Hopefully this will help you with yours. This is for WinXP and Windows Vista. It worked great for me.
*** THIS WILL VOID YOUR WARRANTY ***
1 - Disconnect the HD from USB and power supply.
2 - There are 2 screws at the back. Unscrew and open the box. (The plastic is kinda hard to open be careful)
3 - Now you have a metal box in your hands. Unscrew and open it.
4 - Now you will see a HD and a controller board. There are 3 screws that holds the controller board. Take them out.
5 - Now slide out the hard drive and controller board out gently.
6 - Unplug the controller board (power socket and IDE socket)from the Hard disk.
7 - Look at the back you will see jumper settings. (Mine was set on Cable Select.)
8 - Take the jumper out and plug it to Master ON position. now put it all back together.
Jan 25, 2009 | Maxtor Personal Storage 3200 (M1227310)...
TEAC SRL100 Set clock
The "set time" button on my SR-L100 is located inside the CD compartment. To set the time the unit needs to be in the standby mode. Press and hold the set time button until the time blinks, then use the tuning/clock adj. dial to set it. Hope this helps! Ted
May 26, 2008 | Teac SRL50 Clock Radio
272 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
