Question about Intel D845PT (KD845PTPAK10) Motherboard
Wont boot tred to install wrong memory . now it wont reboot with old memory. it just beeps
    Brigadier General:
  • 5,158 Answers
Recheck that the memory has been reinstalled properly... if it has and you have the same issue swap the memory to the opposite slot(s) it is in.
Posted on Aug 31, 2008
12 short beeps and it wont stop rebooting
I'm not sure what 12 short beeps mean, but it indicates something is wrong with the hardware. Check your ram sticks. Found under a panel on the bottom of your laptop. If you have 2, take one out, try to boot, then swap them.
There are other reasons for beep codes, but they tend to be much worse & less likely.
Jul 23, 2012 | Acer Aspire Computers & Internet
Meening of motherboard beep
The beeps or blinking lights tells the technician what is wrong with the computer. Most times it's a memory or video card issue. If you are getting beeps, try checking your memory.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 24, 2012 | Compaq (261671-001) Motherboard
Keeps beeping when on
Beeps and blinking lights tell the technician what is wrong with the computer. Count the beeps and the pattern of the beeps (3 long beeps, 1 long beep followed by 2 short beeps, etc).
Most times it's something related to the motherboard such as memory or video card.
Did you see anything post on the screen during the boot process?
Check your memory.
Apr 09, 2012 | Acer Aspire 5536-5224 Notebook
Y does my computer keeps beeping and it wont turn on
How many beeps are you getting and notice whether they are long or short beeps? Beeps tell the technician what is going on with the computer. It could be a number of things going on with the motherboard, or things that attach to the motherboard.
Try removing the power cord, opening the case, then taking out one of the memory chips and sitting it aside. Then plug the computer back up and see if it boots. If not, move the memory chip that is in there to the next open slot, then try booting again. If it still does not boot, remove that chip and set it aside and get the chip you already had set aside and move it into the memory slots trying to reboot. If it boots, mark an x with a ink pen on the chip that is set aside, it is probably bad, then put it into the computer's open memory slot and try rebooting. If it fails to boot you know the cause is the chip with the x on it.
Mar 28, 2012 | Dell Inspiron i5602128NBK Desktop PC Intel...
Alarm beeps on startup and will only let me put in 1st digit of password beforekeyboard wont work anymore
Beeping on startup is an indication of a RAM memory problem. If you have more than 1 stick of RAM installed, try removing 1 and rebooting. If it boots up, you may have a motherboard issue that won't allow your machine to utilize all of your RAM memory.
May 14, 2011 | Acer Aspire One PC Notebook
Laptop will not boot with new ram memory card
Those beeps are code for what is wrong,
go here to see what yours mean:
http://networking.ringofsaturn.com/PC/beep.php
Sep 05, 2009 | HP Pavilion dv6000z Notebook
Installed more memory into Compaq V2000
The new ram you have installed, is it the same speed/type as what is already in the system?
Take out the new ram and leave the old in. Try and boot. If all ok, swap out the old ram for the new and see if you can boot. If the system does not boot when trying one of the above, you know it's bad ram. If the system boots with the old ram and the new ram installed seperately, i'ts likely that you have two different types of ram. Check your old ram and see what spec it is. Your new ram should be the same. Compaq do not list a four beep error on boot, but my guess is conflicting ram.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Jan 17, 2009 | HP Compaq Presario V2000 Notebook
Adding Crucial Brand Memory - getting BSOD and reboot
can you still boot if you remove the new memory?
can you boot if you have the new memory installed, but not the old?
what are the exact specificiations for the memory stick you installed? speed, size, form factor?
Mar 29, 2008 | Everex StepNote NC1500 Notebook
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
Intel D845PT (KD845PTPAK10) Motherboard Logo
100 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
