Yep you sure can. Depending on the version of Windows Media Player that you have it's pretty easy to rip the CD and then sync it to your Mix Max. I recommend using Windows Media Player 11 as it's the easiest so I'd recommend you install that first. Then insert your CD into your computer, open Windows Media Player and click on the "Rip" button at the top. Select the tracks on the CD that you want to add to the player and click "Start Rip." Once the tracks have completed ripping click on the "Sync" button at the top right of Windows Media Player. Then just drag the tracks from the library on the left to the sync list on the right and click "Start Sync."
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable * Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu. . Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Check out #7 at http://digiblue.com/customer-service/faqs/disney/mixmax/index.html It has a PDF download with instructions on how to properly encode videos so that they will play on the Mix Max.
If the music is already on your computer, it must be in mp3 format, do the following;
1) Open Windows media Player,
2) Connect your Disney Mix Max
3)Click "sync"
4) "Drag" song to where it says "Drag items here",
5) Click "Start Sync"
Yes, you can download "any" video you want to the mix max, but to do it from a DVD, you will have to first get the video from a DVD and convert it to a mpg file, then follow the instructions here.....
I have Windows Vista and the first time I plugged in the Mix Max it immediately downloaded the device drivers. I opened my Windows Media Player and it already recognized the player. I just transferred songs over walla they are on the player. Hope that helps.
