Question about Texas Instruments TI-83 Plus Calculator
Error message When I want to graph something on my calculator I get the error message: INVALID DIM how can I fix this?
  • bwalker70 Aug 30, 2008
    OH, by the way, this is a TI-38 Plus
I got the solution from someone else. Here it is:
http://www.lcc.edu/mathsci/calchelp/topic6.htm try this website. Scroll down to step number 5. Works great :-)
Posted on Sep 01, 2008
How to fix INVALID DIM in plotting graph
The ERR:INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press y ,and
then select 4:PlotsOff.
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Apr 05, 2014 | Texas Instruments TI-84 Plus Calculator
Error invalid dim
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If you're doing something else, what exactly?
Feb 02, 2014 | Texas Instruments TI-84 Plus Calculator
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
Error message invalid dimensions
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
Error: Invalid Dim
this happened to me as well. i looked it up and heres what i found:
http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot"
one of them is turned on so press enter and select OFF. this should fix the problem!
Sep 18, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
153 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
