Question about iLO V27DMBX Television
Ilo tv where are the diodes?
  • 3 Answers
Take off the back cover of the TV. Be careful around the red wire that suction cups to the top of the CRT - it carries high voltage! On the circuit board, you will see where the power wire connects to the board. You should be able to pull the board out to get to this area. Also, the board can be completely removed by disconnecting a few connectors and gently pulling the board off that connects to the back of the CRT. When disconnecting the high voltage wire from the CRT, there are many resources on the web that discuss the proper way to do that.
The diodes are near where the power wire is soldered to the board. You will see a fuse (which needs to be replaced - just pry it out and drop in a new one - Radio Shack sells these). Then if you go toward the back of the case, you will see some other electronics and then four diodes. They were all black in the one I worked on. And the number on them is in my original post, I don't remember it right now. Desolder one at a time noting its orientation - diodes must go back the same way, and check each one. I used a multimeter that had a diode check function.
Good luck.
Posted on Aug 31, 2008
Who makes these TV.
made for wallmart by ILO
ILO TVs made in China. A few brand have been connected with iLo, are Funai, Orion, Tatung
ILO customer service number is 800-289-0980 or 1-800-939-0605
ILO TV Codes. 11286 11603 11684 11990
ILO TV. 0171 1286 1990 1603 0180 1271 1963 0179 0000 1004 1000 1950 1090 1090
Jul 05, 2014 | iLO IWT3206 TV
Tv wont turn on
hmmm...ok...turn it off for around 20 minutes, to allow all energy to discharge. Then try it once again.
second...check to see that the power from wall is still good(always helps to check that)
Feb 24, 2008 | iLO 2600 Television
I neeed to know how to program my ilo iwt 3206 tv to a one for all urc-3220 remote and cant find a manuall
Try codes for Funai, Orion, Tatung ILO customer service number is 800-289-0980
Mar 28, 2011 | iLO IWT3206 TV
TV is showing it's getting power but will not come on. The red light shows it's getting power but now will not go green.
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | iLO V27DMBX Television
Need a remote
Here's one place to get the remote for the TV;
http://www.remotes.com/store/ilo/rc-2600-ilo.html
The Directv web site has only one code to try for the ILO TV. 10171
Does that code work on the TV?
May 11, 2009 | iLO 2600 Television
ILO 27' LCD TV Start up problem.
depends on what "start up" problem you are having. If it is turning its self off upon turning it on, you need to go to Radio Shack and get a $2 pkg. of diods for the power supply--it's fixing to go out; we could not get any help and figured out what it was and fixed it ourselves since Wal-Mart was useless and had NO customer service.
Dec 11, 2008 | iLO 3200 32 in. LCD Television
Need remote control code fro iLo TV
iLo Tv's are made by orion. When I used their code the Tv remote worked.
Dec 07, 2008 | iLO 2600 Television
Ilo 32hd blown fuse
Diodes are often parallel to other components so if one measures 'bad' it should be desoldered on one end and checked again.
On the diode test position of most all digital meters, they will show between ~400- 900 depending on the type if the lead polarity biases them in the forward (conducting) direction. The indication isn't really too meaningful but roughly equates to millivolts of voltage drop in the forward (conducting) direction. Reversing the leads, especially on the diode range should just cause an over-range indication or the same as when the leads are not attached to anything. Shorting the leads should show very close to all zeroes.
Aug 30, 2008 | iLO V27DMBX Television
Problem with buttons on TV
replace infrared (IR) diode from remote control 100% working or sent me ur remote control i'll fixed for free..dont forget the fee for postage..my email add mandark_jeff@yahoo.com
Feb 09, 2008 | iLO 3200 32 in. LCD Television
iLO V27DMBX Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
