Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Freezer works but fridge does not cool..please help
Kenmore elite model number 596.72289200
mfg no p72289000b0
    Scholar:
  • 62 Answers
Ther are several things that can cause this, one a bad evaparator fan or an defrost problem. Look on the back of the freezer wall and see if there is a lot of frost. If there is then it's a defrost problem and the part most likely is a bad termination thermostat also known as a bi-metal. If there is not a lot of frost, check to see that you have air going to the refrigerator section. If not then it could be the fan.
Posted on Aug 30, 2008
How do I find out the model number of my Kenmore elite Fridge
Since the freezer is icing up there could be many different problems a blockage or a problem with the defrost or timer of the unit if u greeting unit number is should be on inside of the door or back by the condenser best bet from what I see is get a tech to fix it they will find all those numbers that u need
Dec 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite side by side fridge not cooling, but freezer is working ok, please help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 11, 2011 | Refrigerators
My kenmore elite top freezer refrigerator (model 106.72999201) is only cooling the freezer not the refrigerator. Compressor is on. Help,
Switch off the fridge and after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
The circulation fan must be checked to work as if frost forms it can be stuck up . So check if the defrost timer works and also if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 26, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My freezer area works fine, but the fridge stops and starts working continually does anyone please have a solution
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fresh side not cooling
I will assume until you can confirm the model number is near Sears KENMORE ELITE, Model No. 10650594000 But I will need you to double check because Sears always uses a number different than the MFG.
For the moment I need you to remove some things from the freezer and remove the back panel covering the evaporator coils. Look for the coils to be frozen over. If so it could be the adaptive defrost control found inside the fresh food compartment part number 4388932
Or a problem with defrost thermostat or the defrost element. I am here to help, Just let me know, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
May 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator is not cooling
Hello hazraan
Welcome.
You said your Kenmore model 60852990 freezer is working but refrigerator is not cooling.
Lets try a couple of ideas.
Is your freezer filled up where the packages are covering the air vents in the rear of the freezer?
Refrigerators and freezers must share the cold air and circulate between them. If the freezer is packed full with not enough space at the air vents in side it, the fridge will get warmer!
Next,Turn off the fridge and freezer controls, and then go to the breaker box and turn off the breaker to the fridge for 5 minutes!!!!!
Then restart it and the fridge and freezer controls.
This should reset the system and solve the problem. let me know if either were the case.
If either was the reason,it now will take some 8 to 12 hours to gets back to temperature.
Waiting your response.
Huuum, Please remember to leave a rating.
Oct 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 75212 fridge doesnt cool off
Well there is a diffrence between no air flow and not cooling is the freezer working?? We can go from there
Sep 16, 2007 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
249 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
