Question about iLO V27DMBX Television
Ilo 32hd blown fuse
How did you check diodes?
  • ebrandyberry Aug 30, 2008
    I meen what should they read?
  • iLO Master
  • 5,568 Answers
Diodes are often parallel to other components so if one measures 'bad' it should be desoldered on one end and checked again.
On the diode test position of most all digital meters, they will show between ~400- 900 depending on the type if the lead polarity biases them in the forward (conducting) direction. The indication isn't really too meaningful but roughly equates to millivolts of voltage drop in the forward (conducting) direction. Reversing the leads, especially on the diode range should just cause an over-range indication or the same as when the leads are not attached to anything. Shorting the leads should show very close to all zeroes.
Posted on Oct 06, 2008
Power went out no power to ILO-32hd
yes posible power supply is defective if fuse blow then could be defective fet transisters as well shorting best way is to replace complete board if it was surge from electicity.
Mar 02, 2012 | iLO 3200 32 in. LCD Television
I have an ILO 32HD and the HDMI input does not seem to work.. goes from no signal to HDMI 10801 but i get a flash of a picture somtimes.. My first HD and can't see it!!! I have tried 2 NEW HDMI cables...
HDMI issues are almost always the scource and not the TV. If HDMI fails to work then use the component inputs as your picture will still be in high definition when on HD channels..
Nov 11, 2009 | Televison & Video
Cracked lcd trying to buy a ilo-32 hd lcd
You do know that the LCD display will be a few dollars short of a new set ? If your still interested in it then let me know.
May 20, 2009 | iLO 3200 32 in. LCD Television
Ilo-32HD Main PCB Assy
Hey, you can try They have may parts. just remember that the board you are looking for may be made buy another manufacturer and used in other displays. Part numbers might be differen but the same power supply. You can call them and ask them, they have free tech support.
Mar 23, 2009 | iLO 3200 32 in. LCD Television
Blown fuse
check mcm electronics, if the fuse keeps blowing you have bigger problems.
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Aug 16, 2008 | iLO V27DMBX Television
Might wanna check your replaceable lamp. Usually when this goes, there will still be sound.
Feb 28, 2008 | iLO 3200 32 in. LCD Television
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
iLO V27DMBX Television Logo
56 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
