Question about Whirlpool Refrigerators
My ice machine is making ice but will not dispence
I had this problem with mine. It turned out that the whole thing had gotten too cold and literally froze up. I poured a little warm water over the whole thing (including the water feed tube) and that solved the problem for me.
Posted on Aug 30, 2008
Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
Sep 21, 2014 | GE Refrigerators
Refridgerator ice machine rotator rod is not turning
PULL OUT AND MAKE SURE THE ROD/MIXER IS IN THE MOTOR HOUSING,IF ITS SLIPPED OUT YOUR ICE WONT ADVANCE FORWARD...
Jul 17, 2013 | GE Profile 25.6 Cu. Ft. Side-by-Side...
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice dispencer working water dispencer not working
If the machine is getting ice - the micro-switch for the selector, or an onboard relay has failed.
If the ice maker is NOT getting ice - look for the dual inlet water valve to be at fault.
Thanks for using FixYa -a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | Neff K3965XO Side by Side Refrigerator
It's not making ice. It's not even getting the water flow in order to make ice but the water dispencer is dispencing water.
If it will kick a batch out if you add some water to it then your water valve needs replacement. if it has ice in it but wont spit any out then your ice maker is bad. Some nice repair pictures: HERE
Dec 31, 2009 | Refrigerators
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
