SOURCE: 320 GB transcend external Hard dics is not at all detected
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the external drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your external Drive to be detected automatically.
Hope this helps you out.
SOURCE: My External Harddisk 320 gb transcend not detected
I would recommend trying the fix on this page if you are running Windows XP
http://support.microsoft.com/kb/925196
SOURCE: After formatting my currupted external 640GB HDD
The data on the external disk was corrupted because the hard disk from it was dying. Take it out of the case , put it directly in a desktop and test it with HDTune (the free version of course) -it will tell you the damage status and if it's recoverable.
If not then it's dead - junk it.
SOURCE: Transcend 120GB External Hard Drive
Do you have installation disc that came with the Trenscend External Drive?
Other wise visit this website bellow to search for your product and you find it drivers for download.
http://www.transcendusa.com/Support/DLCenter/index.asp?LangNo=0&Func1No=11&Func2No=182#L3
let us know if this solution works for you.
Thanks for using fixya.
SOURCE: Store jet transcend 640gb not
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
