Question about Amana Washing Machines
My Amana front load washer came on and started chimming for no reason the code on the display is e2 and 9 alternating flash.
  • 639 Answers
Friend,
ngfam1 At your service!
Try unplugging the washer for a few minutes and the restarting it as to reboot it, like we do with our computers when the become irregular!
If this does work great!!!
If not try the company I offer you below!
These codes are for you to write down and make them available for the service tech as he can better diagnose your problems!
The service tech needs to check out your electronic system, and remedy your failure. Now before it cost you real money!
Unfortunately some applinaces are built like the cars of today , where you can't fi them your self anymore due to the latest electronics used to operate the system
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 30, 2008
My amana front load washer, model NFW7200TW won't drain it gets down to 8 min of cycle and stop and display nd code. Check pump, fine also I can open washer door when it get stuck in this mode
remove the drain hose from back to see if there is any foreign object stuck in there , if washer faults out on code its common for door to unlock
Aug 16, 2016 | Amana Washing Machines
Washer won't drain, E:13 code flashing
From user manual:
Indicator light "rinse" is lit and display is flashing "E:13" with no water remaining in the drum.
For some reason drain pump is blocked.
Clean the water drainage pipe and/or drain hose.
Dado
Oct 12, 2015 | Bosch Vision 300 Series DLX WFVC4400UC 27"...
During wash cycle on Amanda front load washer, water leaks from the top down the side
Sounds like the door seal is shot. Try searching "amana washing machine door seal". You get YouTube hits on how to and suggested parts suppliers. Alternatively get a local technician to look at it.
Jun 16, 2015 | Amana Washing Machines
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Jan 21, 2009 | Amana 3.2 cu. ft. Top-Load Washer
F-00 flashing control panel w/ time
pannick!........ suggest you check the filter, the fault code suggests that for some reason it cannot empty. Regards Engineer
May 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
141 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
