Question about RCA D52W19 52" Rear Projection Television
My rear projection only powers on for a moment then shuts off then back on then off again...
  • RCA Master
  • 5,138 Answers
Replace 3 capacitors on deflection board, 2200uf and two 220uf 35v they are Green and gold
Posted on Sep 24, 2008
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
As soon as I turn the power on, it shuts right back off immediately. It will not stay on. Any ideas?
there are leds inside that will light up @ the moment of shutdown.. one on the power supply lights up with ANY shutdown, but at the exact moment (like when you try to turn on from cold) of shutdown, another will light for a split second. depending on where this other red led is, will tell you which board is bad. I just spend like 10 hours working on a 510hd model so I know it like the back of my hand, let me know if you want to dive in. These tvs are notorious for having bad solder connections all over several board and can be fixed easily by a savvy tech with a solder iron. Let me know
Jul 12, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Tv keeps shutting off , unplug it for a while it will work again but eventually shuts off again
it sounds like an over heating problem, clean out back if that does not work it most likely is a power supply problem
Jan 17, 2010 | Samsung HCM4216W 42" Rear Projection...
I was watching it and it just shut off when i turn it on 3 seconds later it shuts off again
this set has a self diagnostic feature:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If this has been helpful I would appreciate a vote from you here; if you need direct help:
etower.766@netzero.net
Aug 14, 2009 | Mitsubishi WS-65809 65" Rear Projection...
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Big screen no picture
find the service manuel at www.techlore.com and it tells you what each blinking light means.
jason
tmoore15@indy.rr.com
Oct 07, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv shutting off
when it shuts off, press the power button and see if the power led blinks and if it does let me know the number fo blinks. Please respond to this same post when replying.
Aug 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
