Question about Husqvarna Designer I
Pr 600 I have a super hard time trying to get the machine to recognize the cap driver. What in the heck am I doing wrong?
  • classicterry Sep 07, 2008
    I can not get mine to recognize the hat hoop either. We I turn it on it stays to flatsthe I hit ok and it turns the hook way off to my left looking at the machine. Desperate here. I have jobs to do..
I know this was several years ago that you posted this, but I figured someone searching for an answer may stumble upon this and wonder how to fix it. You have to re-calibrate the machine for the small and large frames. Basically what is happening is the machine's calibration isn't precise and it is getting confused on what frame is on the machine when the hat frame is put on. Once you re-calibrate it, it should work without a problem. It's been a few months since I had to do that, so I don't really remember what to do, but look up frame calibration and you should find it.
Posted on Dec 10, 2012
I'm having the same problem...did you find out how to fix it. I need to get a job out and the Tech has not called back.
Posted on Sep 07, 2008
My pr 600 freezes
You might have Thread particles build up. Puchase canned Air for electronis and use it on a regular basic to clean your bobbin case area. Also when you change threads color always clip your thread near the spool and pull your thread out from the bottom near your needle. When you pull your thread through the top little pieces of the thread break of and fall into the chamber of your embroidery machine .
Mar 05, 2014 | Bernina Bernette Deco 600
Brother pr-600 screen not responding
See if you can discover how to reset the machine. Typically it is a combination of buttons pressed either simultaneously or in order as the machine is starting.
Dec 10, 2012 | Sewing Machines
Shredding thread
Check the needle/throat plate for that station for a burr or other damage. Replace if needed.
Nov 29, 2012 | Sewing Machines
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Nov 04, 2009 | Brother Sewing Machines
I HAVE A BERNINA DECO 600 EMBROIDERY MACHINE (WHICH I KNOW WAS MANUFACTURED BY BROTHER) - I WOULD LIKE TO GET A REPAIR MANUAL FOR IT SO THAT MY HUSBAND CAN REPAIR AND TUNE IT UP FOR ME. ALL THE PEOPLE WHO...
I Have had many machines that I service myself, the Bernina Decco 600 is a very simple machine to service, if your machine is running great it does not need a service, the lower mechanisum is only a bobbin area and nothing much goes wrong down there, apart from cleaning the dust and lint out there is also an adjusting screw if the timing goes out, never put oil on the top moving shafts as they tend to slip and can cause your machine to push out the timing, this machine takes all .pes format design cards, the same as brother, and there is nothing wrong with brother machines, they are very user friendly.
Oct 28, 2009 | Bernina Bernette Deco 600
Brother pr 600 has x axis possition error message.
In most cases customer were emb. bags when or after you get this error message, there is a sensor under the x-axis; horizontal arm; that gets hit and breaks you can try to get a dealer to sell you the sensor and repalce it yourself its really easy, one screw on the side of the x-axis cover and it lifts and slides off and one screw for the sensor plus two flexible flat cables plug into it
May 05, 2009 | Husqvarna Designer I
Wiper error occuring between thread sequence.
wiper error can come from the needle threader not working right, the cutter not working right or the picker not working right, i would recommend taking this to a dealer for service because setting the picker is easy but you have to be in the service program of the machine
Apr 27, 2009 | Husqvarna Designer I
Sewing Machines Logo
111 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
