Question about GE Refrigerators
Freezer/Rerigerator not cooling
I have a GE GSS22WGPDBB which is only 4 yrs old.  It is no longer cooling on either side but all fans are working.  We've removed back panel in freezer and the coils are completely frozen over.  Technician can not come out until Wednesday due to the holiday weekend.  Can you provide any insight to the problem and a possible do-it-yourself fix?
    President:
  • 1,462 Answers
Defrost system has failed. for a temporary repair, melt ice off with a hairdryer but dont heat up any stats mounted on the pipework.
check continuity thro the defrost heater and thermal fuse in series with heater with a multimeter.
if both of these are ok, points to a module fault
Posted on Aug 31, 2008
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Not cooling. i do not hear the compressor. fan is working. 3 yrs old
The condenser fan is very quiet so you may not hear it . remove the lower rear back panel and check whether the compressor and or fan is running . Also check if the back wall of the freezer has frost on it or if the evaporator fan in the freezer is running.
Nov 12, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE Side by Side Refrigerator Not Cooling but Freezer is working
This is a good indication of a failed fan.
The freezer compartment gets first crack at the compressed coolant and a fan distributes some cooled air to the refrigerator side. When the fan fails, the fridge suffers.
Sears parts department has thousands of illustrated breakdowns of many appliances and if yours is one of them, you can see the location of the fan for DIY purposes and often how to access it.
They also have (for listed appliances) the mfr.'s part number and the failed part can often be ordered right from the page on which it is displayed.
Sears Parts Direct
If you can ferret out the part number, you might check listings in your area for Johnstone Supply which supplies trades people with a huge variety of replacement parts and the prices are often 40-60 under dealer prices for the same items and have never turned me away as a non-professional DIY person.
Jul 13, 2010 | GE Refrigerators
Ge fridg and freezer not cold; just cool; TFX 20JR; what could the problem be?
The problem is probably the defrost heater . This model is at least 12 yrs. in age . Pt # WR51X442 is the part number for the heater and harness kit . These parts are located behind the inside rear lower freezer panel . First , make sure the freezer fan is working . If not Pt # WR60X10008 is the freezer fan motor .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
GE Side by Side Not cooling/freezing
sounds like defrost problem. remove back lower panel in freezer. defrost all ice on coils, this will fix problem temporaily. I`m looking for the tech sheet to test system.
Jul 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Have side by side refrigerator (approx. 10 yrs old). Fridge no longer keeps food cold enough even at highest setting and freezer isn't as cold either.
Your refrigerator needs to be turned off and aompletely defrosted. Overnight if possible. You have a large amount of ice built up on the freezer coil that is blocking air flow.
Most refrigerator sections are only cooled by air flow from the fan in the freezer section.
Thaw it and clean it out real good and you should be back in business.
Jun 10, 2008 | GE Refrigerators
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
208 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
