Dometic RM2852 Refrigerator Logo
Posted on Jul 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Refrigerator does not cool properly. Freezer seems to be ok.
Anonymous
Level 2:
President:
  • Expert 3,773 Answers
  • Posted on Jul 28, 2011
Anonymous
Expert
Level 2:
President:
Answers
3773
Questions
Helped
609579
Points
163
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 05, 2007
SOURCE: refrigerator problem
3 most common things that cause this are a defrost problem (will notice frost build up on back freezer panel), bad evaporator fan motor (should hear fan running in the freezer), or bad damper (vent to the fridge section). If no frost and fan is running check for air flow out of the vent. It should be at the top of the fridge section.
Anonymous
  • 828 Answers
  • Posted on Jun 28, 2008
SOURCE: Kenmore side by side refrigerator not cooling
Check inside back wall of the freezer for frost buildup. It would be a sign that the defrost system is not working and the coil inside the back wall is frozen over stopping air circulation to the refrigerator.
Defrost system has a timer that energizes a heater and a defrost termination switch which shuts off the heaters when the coil is warm enough for all ice to be melted. If you have the frost, locate the defrost timer and turn the clutch head screw clockwise SLOWLY until you hear one audible click, the compressor will shut off and the system will be in defrost. After 18-22 minutes the refrigerator should restart automatically. If it does not restart after 25 Minutes turn the timer screw again to the second click. Refrigerator will then start. Replace the timer.
If it restarts after the 18-22 minutes and does not defrost ether the heater or defrost thermostat is bad.
lenwest
Len West
  • 150 Answers
  • Posted on Jan 31, 2009
SOURCE: not cooling properly
Sounds like your coils are getting plugged,(excess ice in and around the coils)if you have a cooler or some other place to keep your food cold,turn off or unplug the fridge,you want to defrost it,for the freezer place pans of hot water in it to speed up the process,leave doors open,should only take around 4 to 12 hrs.A good time to clean it to lol.
Hope this helped.Let me know.Also rate me.
For more help go to live chat.
lenwest
freetek
Steve Allison
  • 5569 Answers
  • Posted on Mar 16, 2009
SOURCE: Refrigerator and Freezer Not Cooling nor Freezing
That leaves only one possible fault; the volatile component of your coolant/lubricant has escaped.
If the unit has been moved or cleaned carelessly, one of the coolant- bearing tubes has developed a leak. Any refrigeration tech will have a leak detector in his tool set so it shouldn't be difficult to find.
Depending on the area in which you live, expect the troubleshooting and recharging to run ~$150-$250 US.
If you reside in the US, check your local (area) Better Business Bureau for a trustworthy service company.
Anonymous
  • 103 Answers
  • Posted on Jun 03, 2009
SOURCE: bottom of refrigerator is not cooling
Hi: Is your freezer so full it's blocking the vents? If so unblock the vents. If not put your food in a cooler, frozen and fresh. Unplug your refrigerator. Take a hair dryer to the back of the freezer to melt frost accumulated behind the panel. I know it's supposed to be frost free. You have a problem with the defrost heater or the timer. The frost is blocking the vents. Most likely it is the later, but if you see no frost it could be the circulating fan. The location of these will be in your parts list. Kenmore still gives these with their products. If you don't have it go to sears.com and use parts direct. They will have a diagram. I hope this helps, Jeff By the way, If you are not handy just do the hair dryer thing and it will work for a weed or two until the frost plugs it up again.
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
The refrigerator compartment is not getting cold. freezer seems ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Refrigerator is running, but it does not seem to be cooling. Freezer side seems to be ok. Have cleaned coils.
Not detailed description of your Refrigerator Problem?
1) Frost free system (Heater, Timer, Drain heater) properly not functioning.
2) Evaporative Fan not working (Check Air flow satisfied or not)
3) Compressor properly not working.
4) Thermostat (1,2,3 ) problem. (Rotate high and check)
The freezer seems to be working fine but the refrigerator is not cooling properly
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
heatman101
Fridge not cooling properly, but freezer seems to be working
heatman101
Freezer too warm without change of previous setting; motor seems to be running ok.
heatman101
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
