Question about Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn My copy its coming out fade it, when I do it in color comes out ok, just with the black ink comes out the top ok middle section fade it and the end a little bit darker, please help me.
  • info58 Oct 07, 2008
    I have similar problem.
    Black print is very weak/faint on left side of printout.
    No use to make copies as text is hard to read.
    Printer is almost 1 year old and otherwise really good.
    I changed to new black color, but problem still remains.
    Anyone with som tips on how to adjust or clean some parts so it works again? Buying a new image unit will be quite costy.
    Regards HW
  • judystephens Oct 07, 2008
    I have the same problem. More to the left side but almost in the middle the print is faint. It is actually getting lighter and I have changed to a new cartridge of black twice. Anyone???
My copy its coming out faded in the center of the text. There seems to be a swath from top to bottom in the middle of the page that is faded out. It seems to be on black only,
Posted on Oct 21, 2008
    Problem Solver:
  • 7 Answers
This is usually due to the imaging unit going out, but can also be a problem with the main board itself...unfortunately that means rma is really the only option...which is NOT going to be fun fyi as samsung has poor customer service.
Posted on Oct 19, 2008
Samsung CLX-3160FN problem with faded black images/text only
Many of today's printers have a "toner save" option, which makes the black appear lighter, and I'm pretty sure this isn't your problem. However, I wanted to rule-out the obvious first, which is just a setting.
If you're seeing the black lighter in vertical "stripes" or segments in your printing, then it's most likely due to a dirty toner cartridge (but you said you replaced it), or cleaning the LSU inside the unit (as it says in the owners manual).
Just in case you don't have the manual handy, here's an online link to it:http://downloadcenter.samsung.com/content/UM/200611/20061122152910875_CLX-3160_English.pdf
I hope this helps!
Feb 13, 2012 | Samsung CLX 3160fn All-In-One Printer
I have a Samsung CLX-3160FN multi-function color laser printer. It recently started to print poorly in black (that's what I mostly print). Geniune Samsung toner carts are installed. The black is at 76%. I...
If the black toner prints like the image below with alternating bands of light and dark printing, the problem lies with your imaging unit.13911cf.jpg Specifically the developer blades in the imaging unit has toner build up on the blades. The more you use a particular color, the more it builds up to the point that it exhibits itself as faded images on the paper.
It can be fixed by replacing the imaging unit for $100+, but it will reappear again after sometime. Or you can fix the problem yourself and save yourself $100. You will need to open the imaging unit and clean the blades. I have a description on how to do this in my tips section. Or your can click on this link, http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300. Hopes this helps you.
Jul 06, 2010 | Samsung CLX 3160fn All-In-One Printer
Light swath of printing down middle of page..
This is due to Black developer , Kindly approach authorised service center to get it changed.
Best Regards
Mar 01, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! Can...
Try printing the demo page, there's a man on there with a black tuxedo. If you see snowflakes on the black suit, you need a new hi voltage power supply circuit board. Also most of the generic toners don't work well in this machine.
Feb 05, 2010 | Samsung CLX 3160fn All-In-One Printer
When i print,the black colored lettres and lines show faded although i put a new drum. The colorprints are still good.
This problem arises if the printer is not used for along period/ might occur when the ink is change. Compare it to the case when a fountain pen is refilled. it takes a few time to get perfect flow.
This might be also due to the clogging of black ink inside.
Try the following operations from the printer properties dialog box:
Cleaning/ deep cleaning
Nozzle check
Hope this helped
Jan 07, 2010 | Samsung CLX 3160fn All-In-One Printer
Black ink printing
black developer rollers need replacing.common fault.
Aug 06, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
190 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
