My 52 inch rca rear projection tv powers on for a moment then shuts off
    President:
  • 1,263 Answers
It seems that your set power control chip is shorting out. this can be replaced by a repair technician. the cost should not be too much because this an easy fix. please rate this solution...thanks
Posted on Aug 30, 2008
    Genius:
  • 1,269 Answers
Try to turn off your tv for about 2-3 hours, unplug the power cable. If that doesn't work, there's a problem with the power supply chip. You may need to replace it. Better check the circuit board of the TV to identify which component is burned.
    Genius:
  • 1,847 Answers
The power supply seem to be faulty
  • Legin Varghese
    Legin Varghese Aug 30, 2008
    On the collector if Q416, there's a capacitor
    That is the snubber capacitor
    You have to increase the value of the snubber capacitor in 20%.
    This is a test to see if the problem in the X-ray circuit or in the capacitor, itself.
    If you are not a TV tech, ask a tech to do such a test for you.
    This device has dangerous HV inside
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 INCH RCA REAR PROJECTION SHUTS OFF
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 inch tv
Clean Board Then Replace R14718 260880 And R14719 175046 And Hv Splitter 258512 And Horizontal Output Q14401.
Apr 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Rca 52 in rear projection not staying on
2 things,
1....capacitors in a power supply 2200 25V, 220 35V (2) and 1000 25V.( upgrade 35V all)
2.---loose connections fly back terminals. (resolder)
Apr 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA P52921yx2 WIll not power on only clicks
try to check the h-transistor and test it with 360tr multi tester and if not deffective try to also check the r2m zener diode
Nov 29, 2007 | RCA P52921 52" Rear Projection Television
1993 52 inch rear projection rca tv
i have this kind of tv1.gif model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
Nov 03, 2007 | LG RU-52SZ30 52" Rear Projection...
Tv loses power
the processor on this et will shut this set down for number of reasons. a technician should be albel to read error codes form the processor to help deterine whatt is cause the shutdown
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
