JVC VM-42wv74 Problem
I am having an intermittent problem with my display. It periodically displays what I call a "gamma" problem that flashes up in the lower half of the screen. I have attached a photo of what it is doing. This is not a constant thing, nor can i find anything that I can do in order to make it happen. I am assuming that it is not something terribly wrong with the display portion since at other times it displays the image perfectly in the same areas? It only flickers the problem on and off at times there seems to be either vivid bright colors in the bottom area, or very dark regions that cover a large area of the screen.
I dont mind doing some parts replacement if you might can tell me what parts to replace and where to get them! It is currently hooked to me Mac as you can see in the photo, but problem persists when hooked to any input, composite, S-Vid or Digital. If you woudl rather, my email is madison.p@insightbb.com
Thanks in advance,
Philip
  • 4,234 Answers
If the unit is under warranty, send it in for service. Send along the picture as it will help to show the problem. Explain as well that you can not force this to happen thus it is an intermittant problem. That will help if it can not be "fixed" at this time. The re-appearance after the warranty ends will still be covered as it was reported during the warranty period. This is usually a logic problem within the video processing. Unfortunately, without reproducing the problem and measuring inside the unit, there is little that can be done remotely to resolve this.
Dan
Posted on Sep 03, 2008
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
I have an everlast treadmill Jx-269e showing error e09. Any idea what to do about that please?
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you65723e8e-6bcc-4a02-900e-e9fa117bb428.gif
Apr 03, 2013 | Exercise & Fitness
My horizon treadmill immediately stops after 2 seconds
StarTrac 4500 Treadmill NO RPM Error Probable Cause A) Damaged or misaligned RPM sensor
B) Display Cable
C) MCB
D) Filter Network
Corrective Action A) Check the connection of the RPM sensor to the lower control board. Inspect RPM sensor and disc for build up of dirt, dust, or debris. Clean if necessary. Verify RPM sensor and disc are properly aligned. Units equipped with an "optical" RPM sensor (uses plastic RPM disc) should have the disc evenly spaced between the walls of the RPM sensor. Adjust if necessary. Units equipped with a magnetic "cherry" RPM sensor (uses a metal RPM disc) should have the sensor spaced 1/8" away from the flywheel. Adjust if necessary. B) Inspect the display cable for any nicks or breaks. Replace if necessary. If there is no visible damage to the display cable, wiggle the display cable to verify intermittent connection. If by wiggling the display cable, the PWM LED on the lower control board does not flash or intermittently respond, replace the display cable.
C) Refer to the NO RPM Flowchart from the service manual for MCB testing.
D) Refer to the NO RPM Flowchart from the service manual for testing of Filter Network.
Star Trac 4500 Treadmill NO RPM Error Code
Jun 28, 2012 | Startrac Fitness Products Exercise &...
Treadmil t733 shows E9 error and soes not start
Dear Sir:
Hello I hope you are o.k
I wil give some tipoe with this Error code:
Error 09 - Lower PCA Memory Test Errors
Description
Possible Causes
Possible Remedies
Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 28, 2011 | Exercise & Fitness
It does not start and shows E9 error
Dear Sir:
I hope you are o.k
I will help you:
Please follow this step:
Description
Possible Causes
Possible Remedies
If you need additional Help , please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
K700i gamma problem
Hi
Go to Settings > display > brightness adjustment (adjust here) > contrast adjustment (adjust here) > back to main page.
Supriyo DG
Apr 15, 2008 | Sony Ericsson K700i Cellular Phone
Televison & Video Logo
689 people viewed this question
Top Televison & Video Experts
Electro Med Services...
