Question about Cameras
Fuji A350 finepix wont read media xd card - Cameras
  • uncle pat Aug 30, 2008
    tried many cards wont read any of them
    tried that....  wont work  but the cards will work in mhy sons A550
  • Cameras Master
  • 6,487 Answers
The problem here is on the camera already, probably the memory card slot might be broken...So better take it to a repair center..
Hope that helps...........
Posted on Aug 30, 2008
    Genius:
  • 3,422 Answers
HI,
Please format your card in the card reader of your PC.
    Genius:
  • 1,847 Answers
Did you try any other card. check if it work with other memory card.
  • Legin Varghese
    Legin Varghese Aug 30, 2008
    If it works then it is issue with the card.
    Try format the card and then try. still no go the card is bad replace the card
My camera won't let me take any pictures or look at them. Everytime I turn it on it says memory card error, card locked. i've tried moving the locked switch on the side of the card up and down but that...
Okay I think there is a sequence of errors that have happened.
According to my specification of your camera it works with an XD Picture Card NOT an SD card.
First I'm going to assume you put a new memory card in your camera to take the pictures of your "Art GCSE" If this is so then the card needed formatted to the camera (your camera manual may call this initializing) and you have inserted the correct card type. Also the maximum size of the XD card that can be used in your camera is a 512MB. Again if this was the case the camera wouldn't "see" the memory card. I'm sure the camera would have malfunctioned before you started taking your project pictures given warnings or shut down. Can you turn on the camera and see your pictures in the "Play Back" mode? Are you sure you have listed the correct camera make and model. It sounds to me as if we are talking two different cameras here because the XD Memory Card doesn't have a lock the SD memory card does The SD memory card doesn't fit in your Fuji FinePix A350 camera Also the camera you have listed here doesn't have an internal memory it has to work with a memory card Just below here is a link to a PDF Manual
Manual link in PDF format
http://www.google.ca/#hl=en&source=hp&biw=1224&bih=834&q=Fuji+FinePix+A350+PDF+manual&aq=f&aqi=&aql=&oq=&gs_rfai=&fp=6a0673dc5c3f3912
Can you put the memory card that you feel has the pictures on it and use the camera Play Back mode and see pictures?
Jan 10, 2011 | Fuji FinePix A350 Digital Camera
Communication error with camera and computer Fuji FinePix A350. Cannot download pictures from camera to computer.
I highly recommend that you instead consider using a card reader to move the photos or videos to your computer. Card reader's do not require software (although Windows 98 and earlier may require drivers), are very inexpensive, are much faster downloading files from the camera, do not use the camera's batteries during the download, and are much less prone to file corruption of the photos during the download.Really, it would be better for the camera user if one of these was included with the camera instead of the cable and bundled software.You place the camera's card in the reader, plug the reader into the USB port, and your computer sees it as a hard drive. You simply copy/paste or drag/drop your photos onto your hard drive. For this simplicity, most professional photographers utilize card readers exclusively. You'll save yourself a lot of heartache if you convert to using one of these. Also make sure that you get a reader that is clearly stated capable of reading your card, particularly if you use SD-HC, XD, CF, or MS cards.
Thank you!
Jul 23, 2010 | Fuji FinePix A350 Digital Camera
Xd pitcure card
Hey there,
the Biggest xd card that you can use for your cam is 2Gigs. Let me know if you need more assistance alright.
Oct 06, 2008 | Fuji FinePix A350 Digital Camera
New Fujifilm xD Picture Card M 2GB
I get the same error message with Olympus 2GB xd M card. I tried formatting as described on http://www.fixya.com/support/p223298-fuji_finepix_a350_digital_camera/manual-1371/page-27 and page 28 but it did not work for me. :-((
Aug 29, 2008 | Fuji FinePix A350 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
FUJI A350
dont know if this helps but i had a problem that was similar, turns out card is not compatible, check here to see if you have a compatible card
http://www.fujifilm.com/products/digital_cameras/accessories/card/index.html#compati
Nov 26, 2007 | Fuji FinePix A350 Digital Camera
Won't turn on
I have had my camera for 1 year and periodically it will not turn on, I have tried everything from checking the batteries to checking the card. I have come to the conclusion that sometimes this camera just will not work!
Oct 27, 2007 | Fuji FinePix A350 Digital Camera
A340 camera
Update Firmware.
I went to fujifilm website and followed the instruction they provided there. The new XD card worked after I installed the new firmware.
http://www.fujifilm.com/products/digital/download/index.html
Good Luck
Oct 10, 2007 | Fuji FinePix A350 Digital Camera
Xd picture card
Hi, You have to go to the menu/setup function. Check the different settings. One of them would lead you to the memory card settings, from there you should be able to format the new card. Good luck and kind regards.
Sep 22, 2007 | Fuji FinePix A350 Digital Camera
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
