Question about Samsung SYNC SGH-A707 Cellular Phone
My phone keeps shutting itself off once I tried to turn it on.
So once i press and hold the power button, then the phone start to turn on and the loading screen with the bar pop up, but once the bar is finish loading the phone automatically shut off and start loading again, and this process continue on and on. is there anything i can do to fix this problem?
  • mjg9829 Aug 31, 2008
    My Samsung SGH-A707 phone stays on about 1 minute then shuts down and then it powers up on its own. This problem just keeps repeating. I have already replaced the battery but the promlem still occurs. Any more ideas?
  • Anonymous Mar 22, 2014
    when i press the power button it turns on and off ive had thi phone not long but its not new and it just started doing this. I took the battery out and everything but it is still doing it
  • 446 Answers
Replace the battery pls
Posted on Aug 30, 2008
  • ariel santos
    ariel santos Sep 04, 2008
    the firmware is corrrupted, you need to send this to a repair shop
Phone turned off itself and i turned it back on, it now says "try again in 538472 minutes"
Do a Full Reset THIS WILL DELETE EVERYTHING!!!!!!!
  1. Press and hold the Volume down and Power buttons at the same time until you feel a vibration (about 10-15 seconds).
  2. When you feel the vibration, immediately press and hold the Volume down button until you see a large exclamation mark.
  3. Once the exclamation mark appears, press the following four buttons in this order: Volume up , Volume down , Power , Volume down . Your phone should now reset and restart itself. (It might take a while for the reset to finish.)
Try again in 134600 minutes
Settings personalization
Jul 10, 2015 | Nokia Lumia 530 DUAL SIM Dark Gray Factory...
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
My Kyocera Event 3g smartphone keeps turning off and on by itself over and over again every time i take the battery out and put it back in i don't even have to press the power button because it turns on by...
Sound like you have to restore the phone and if still persist..phone replacement if battery is good.If you have an SD card in phone remove it please. Make sure your picture and contacts are backed up to SD card. This will take phone back like new.
    • Turn off the phone.
    • 2 Hold down the "Volume," "Power" and "Home" buttons at the same time. Continue holding the buttons until the 3-D Android logo and a menu of system options appears on the screen, and then release the buttons.
    • 3 Press the "Volume" button to scroll through the menu options and highlight "Wipe Data/Factory Reset." Press the "Power" button to select the option.
    • 4 Use the Volume button again to highlight "Yes, Delete All User Data," and then press the "Power" button. The Event deletes all your personal data and settings from the phone and then returns to the first menu.
    • 5 Highlight "Reboot System Now," and then press the "Power" button to restart the phone. After several minutes, the Event starts up and opens the main screen, giving you the option to set up the phone just as if it were brand new.
Feb 10, 2015 | Kyocera Cell Phones
LG optimus Titanium P509
A couple options. Haven't tried so you'll have to see if they work.
Try booting into recovery mode and clearing the cache:
1. With the phone turned off, hold the Power and Volume Down button for several seconds until the device turns on
2. Select recovery mode using the volume buttons
3. Clear cache.
You may have to do a hard reset, however:
WARNING: All of your data will be lost!
1. Remove your SD card
2. With the phone turned off, hold the Home and Volume Down button and keep pressing them, then
3. Press and hold the Power button too until the device turns on
4. With VOLUME buttons select wipe data / factory reset
5. Confirm with Menu? key.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 01, 2014 | Cell Phones
I did try: change fuse as first it was without any lights. Then checked sockets. It started again by itself. Then I reprogram it-switch off-turn on 90'C-press start button- switch on- keep pressing f
Try this reset, it may work:
-Turn Off power switch
-Select 90 degree washing
-Press and hold Start
-Turn ON power switch and keep pressed Start button 10 sec
-Depress Start button
-Turn Off power switch and turn On again and thats it...
Credit to original poster :)
Oct 19, 2012 | Washing Machines
I am trying to reset my toshibe m45 s165 to its factory settings, but when i try the whole press "0" and power at the same time, the laptop keeps turning off since im holding the power button,...
Do not hold the power button down while pressing the "0" key - it'll shut the computer off again. You just need to push it once to turn the power on and then hold the "0" key immediately after you push the power button on - just like turning on the laptop, but this time you're holding the "0" key down.
Feb 05, 2011 | Toshiba Satellite M45-S165 Notebook
Apple 20 in Imac G5 turn on for about 40 second and shut it down itself .. please help
Sounds like you need to reset your SMU and NVRAM:
To reset your SMU:
  1. Turn off the computer by choosing Shut Down from the Apple menu, or by holding the power button until the computer turns off.
  2. Unplug all cables from the computer, including the power cord.
  3. Wait 10 seconds.
  4. Plug in the power cord while simultaneously pressing and holding the power button on the back of the computer.
  5. Let go of the power button.
  6. Press the power button once more to start up your iMac.
To reset your NVRAM:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
If those don't resolve the issue, your computer will probably need service. Good luck!
Oct 10, 2010 | Apple iMac G5 Desktop
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
Phone doesn't power on
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Aug 12, 2009 | Apple iPhone Smartphone
Mac Mini G4 turns itself ON
Have you looked into System Preferences>energy saver>schedule? Maybe it's set up to start itself. I have my mother's mac set to start up and shut down automatically. Just a thought.
Jan 09, 2009 | Apple Mac mini G4 Desktop
Samsung SYNC SGH-A707 Cellular Phone Logo
391 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
