Question about Panasonic PV-M2058 20 in. Combo
Blue rectangle at bottom half of screen??
Looks like a manufactures advertisement, displaying in text all the functions of what the tv can do. When I change the channel or change volume, the blue rectangle will go away momentarily, only to magically POP UP AGAIN, and again, and again. If someone has a solution to this problem, I thank you in advance for the help
Hold down the Rewind button and the Play button simultaneously for about 7 seconds. The TV should turn off. Then turn the TV back on. Go through the setup procedure. The box should be gone. This worked for me anyway. Good luck.
Posted on Nov 22, 2007
  • ashright1234 Jul 13, 2011
    OMG! I cant believe this darn TV didnt have a menu button on the actual TV. I lost my remote and couldnt find a TV code for the life of me for the Universal one I had! The TV was previuosly programmed with just channel 57! And this rebooted the whole thing which allowed it to auto channel search upon powering it up again. Now I have all the channels! I dont mind gettin up n changing the channel manually. THANK YOU!!!
    Novelist:
    Champion:
  • 277 Answers
Try to change the Caption mode: Press ACTION to display the MAIN MENU Select TV - CAPTION - OFF It should help.
Posted on Sep 12, 2005
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
Hello
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
The volume of sony wega kv-sw29m61 set always to maximum when it turned on
On your remote control (with tv off)
1. press Display, channel 5, Volume Up and then Power
this brings up the service mode (you will see some green text on your screen)
2. Press channel 2 to scroll through options until you see "Micro" in the upper left of your screen
(channel 2 cycles up through the options, channel 5 cycles down)
3. Press channel 1 to scroll through suboptions until you see "DIOF" appear under "Micro"
(channel 1 cycles up through the suboptions, channel 4 cycles down)
4. Press channel six until the default value (12:60) changes to 12:40
(channel 3 increases the value, channel 6 decreases the value)
5. Once the value has been changed to 12:40, press Muting and you should see red text in the upper right hand corner that says "Write"
6. Simply turn the power off and back on for the change to take effect. Your volume problems should now be fixed.
Jan 16, 2010 | Televison & Video
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Oct 26, 2009 | JVC Televison & Video
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
It's the 26 inch version but have problem with picture
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Dec 19, 2008 | Olevia LT32HVE 32 in. LCD Television
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Open Questions:
See all Panasonic PV-M2058 20 in. Combo Questions
Panasonic PV-M2058 20 in. Combo Logo
196 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
