Question about Dell E172FP 17" LCD Flat Panel Monitor
Tyris Tyris 17" LCD F179 T701DB monitor image appears for 2 secs
I have a Tyris Tyris 17" LCD F179 T701DB monitor image appears for 2 secs and then the screen goes blank.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Tyris Model: F179
No Power
Purchased an AsIs non-Working Tyris F179 from Goodwill for $15. Opened the case, found no swollen capacitors. Tested the capacitors on the power board and found C203 680uf 16v and C202 680uf 16v only partly working. Could not find a pair of 680uf caps and since they were in paralell on the same traces I removed both of them and substituted with a single 1500uf 16v capacitor. Next, the video board does have a Novatek chip much like the Novatek chip in the Samsung 710n but look closely at the 5 and 6 legs, they are not being used in the Tyris design so the 5/6 50ohm resistor fix is not needed here. Did find C107 , C16, C50 weak, all 47uf 16v, so i replaced them. Reassembled and now have a great picture again.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
For Reference_Novatek Chip goto near bottom of page
http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
Posted on Mar 09, 2009
  • 20 Answers
Sounds like a bad inverter or CCFT(s). Adjust the brightness to the darkest setting. If the display stays on longer, the you have a bad CCFT(s). If it still goes out the suspect a bad inverter.
Posted on Nov 24, 2008
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
What should the tyre pressures be on a vw sharan vr6, 225/45/r17?
Tyre pressure is given by the manufacturers for both ride comfort and wear. For comfort, most are recommending 32 PSI, I personally have found with the lower profile sport tires, that running 35PSI gives the best ride and tyre wear.
Oct 06, 2009 | Microsoft MNTR TYRIS|LCD 17' 8MS DVI...
I have a Hyundai Image Quest L70S, the screen goes blank
hello, mine lcd it is extinguished continually. I have tried to open it and seems us or a problem on a condenser dell' inverter. Someone you would know dirmi where to find the outline in order to understand like repairing it?
Jan 08, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
Dec 03, 2008 | Microsoft MNTR TYRIS|LCD 19' 8MS DVI...
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Screeen comes on --then goes blank
Your inverter circuit is faulty. This controls the lights inside the screen so you can see what is happening on the LCD panel itself.
If you shine a torch into the LCD from the top at an angle you will still see the images on the screen. But with no light inside to project it outwards, it's dark.
A local TV repair shop should be able to do the reprair fairly cheap, but it's best to make a few phone calls and check they will work on an LCD monitor firstly, and secondly a rough quote.
This is a very common fault with LCD monitors.
Hope that helps =)
Apr 15, 2008 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Monitor is blank/black
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT)
who is not "technically inclined." If you really want to fix this
particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | Star Logic 17" LCD Monitor
Screen goes blank after 2 seconds!
Blank Blank or can you see shadows?
If you see shadow images then the backlight or inverter has failed
If it is blank blank then graphics card or connector/cable problem
Does that help
Dec 30, 2007 | HP Pavilion F1703 17" LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
822 people viewed this question
Alun Cox
