Question about Intel Motherboard
Intel motherboard replacement
Board d865pcd installed today as replacement. Can get green light on board to light up but can not get processor or anything else to start from front switch.
Driver sound on board d865pcd
Posted on Apr 26, 2009
  • 114 Answers
Did you check to make sure the connector for the front panel buttons are connected?
Lou
Posted on Aug 31, 2008
Motherboard Cpabilities
Look at the large chip next to the CPU slot. If you see 865G then click on this link
http://www.intel.com/support/motherboards/desktop/D865GLC/sb/cs-008974.htm
The manual can be found at:
http://downloadmirror.intel.com/15206/eng/D865GBF_D865GLC_ProductGuide02_English.pdf
If the notation is 865P then click on this link:
http://www.intel.com/support/motherboards/desktop/d865pcd/sb/cs-010434.htm
The manual for this board can be found at:
http://download.intel.com/support/motherboards/desktop/d865pcd/sb/cdenglish.pdf
The boards are very similar. The G chip board can handle 4MB RAM. The P board only 2MB.
If you can give me the model number or the Service Tag number of the computer, I might be able to give you more info.
Thanks for using Fixya.
Feb 05, 2010 | Dell (E210882) Motherboard
I dont't get display in my moniter my board is intel dg43nb ram 4 gb, core 2 quad processor fan move green led light but n display
check the ram to know if it is actually working or sitting properly.......check the VGA port...........try another monitor on your board........lastly try the monitor on another board and if it works you board is bad
Jan 31, 2010 | Intel DG43NB Motherboard
REPLACED MOBO INTEL D845EPI/845GVSR EMACHINE 2.5 P4 REPLACED PROCESSOR... NO DISPLAY OR KEYBOARD RECOGNIZED, NO BEEPS NOTHING BUT FANS ARE RUNNING AND LIGHTS ARE ON?
1.*********** Board not supporting Your Processor.
2. Try With Lower Speed Processor
3. Mahe sure that Mother Board is Working or Faulty.
4.Check the ram twice
If it HELPS RATE ME!
Jun 24, 2009 | Intel Desktop Board D845EPI Motherboard
I want to find out the software for installing builtin LAN IN intel D865PCD
Intel D865PCD motherboard.
The LAN driver software is part of Intel's chipset driver. You'll need to download & install driver, number 2 from the Intel link below; (This is normally done after a fresh install of windows.
Before you run Intels software make sure the builtin LAN has been [Enabled] within the bios.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1671&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Cheers
Jun 08, 2009 | Computers & Internet
I have p4 3.06 ghz processor on mother board it is written P5P800-vm/s i require VGA and sound drivers(realtek ac97 sound driver} i have i P5P800 VM motherboard and i was wondering if i can upgrade it's...
NO. you cannot install DUO to *********** board. the DUO is pinless and the P4 3.06 is pin type if you want to upgrade your PC you have to replace the mother board too.
May 18, 2009 | ASUS P5P800-VM Motherboard
478 PENTIUM 4 MOTHERBOARD (intell) d845ebg2
The green led light on the motherboard mean the board has stand- by power to it. (This is normal).
You stated you installed a new CPU.
The high pitch you heard could mean you did not add thermal grease or thermal tap between the processor & the heat-sink assembly. (A must have product). When you press the power on button on the case & nothing seems to run, Re check your memory & as Smithbrother suggested insert one stick of memory at a time & try powering up the system. If you have an AGP card already installed, re-move it & re-seat it.
Intel list a bios update. This update is for - B-0014.
Fixed the issue with booting using 2.0Ghz processor.
Your new CPU of 1.7 is close. (Not sure if this will fix your problem. Save flashing the bios as a last ditch effort).
Here is the Intel link for your motherboard;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=823&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Just in case I'll include a YouTube video on how to install a CPU;
http://www.youtube.com/watch?v=FyK-roVdx7c
Mike
May 09, 2009 | Computers & Internet
No power to motherboard Intel D865PCD, replaced pwrsupply with known good one, no power to cooling fan. Blue board light comes on. I removed all connectors, this is a new board.
Hi there.
make sure that the power connector (it will say PWR on it) is connected to the pwr on the front panel >>3f59fa1.jpg it will look something similar to this.
Post back if no results
Good luck and thanks for using Fixya!!!
Feb 18, 2009 | Intel D865PCDL (735858167413) Motherboard
I bought a mother board from a swap meet but it didnt come with the wiring up diagram and im lost as to how to wire it up only for the power reset etc.. not sure which way they plug into i think i have...
Hi kjstenny, not sure where you saw the board E210882. This is not a valid Intel model number. The Intel D865GLC is a valid model number & you can download the manual for this at the link below:
http://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
Main Intel link for D865GLC:
http://support.intel.com/support/motherboards/desktop/D865GLC/LC_manual.htm
MB layout page 14 & 15. Than see page 13 block D, J9J1 Front panel pins. Page 43 for jumper connections.
Intel D865PCD (Matched). Front panel, page 34 & 35. Download manual at this link:
Main link: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1671&lang=eng
Intel D865PCK - (No Match). (Or no longer listed).
D865PE50 - (No Match). (Or no longer listed).
The most common wire color for each 2-pin connector will be negative, including the color black.
Good luck kjstenny!
Still need help, just post your question.
Mike
Dec 03, 2008 | ASUS A7S333 Motherboard
DX38BT
did you install the heatsink with thermal compound before installing windows?
Sep 27, 2008 | Intel DX38BT Desktop Board (BLKDX38BT)...
GRAFICS PROBLEM
What grphics card are you using with the board?
 What are the issues exactly?
Feb 23, 2008 | Intel D865GLCLK Motherboard
Intel Motherboard Logo
85 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
