Question about Sharp AR-M205 Copier
Sharp ar-m205 copier
Aside from the fact that the multi sheet feeder on my copier doesn't work with out jamming (brand new) i can't seem to copy anything but a blank sheet of paper. (which it does well, by the way) i have followed the stupid pictures on the toner to the letter, but it refuses to so much as leave a mark on a peice of paper. i am in a Marine helicopter squadron in Iraq, and this is the only copier we have, and we are considering it for target practice. please help save the poor (brand new) copier. sbookeydoll@yahoo.com is my personal email address
  • sbookeydoll Aug 31, 2008
    i even tried to copy a black peice of paper laid on the glass... the fact is, no toner is comming out of the cartridge. i don't have another cartridge to test, so i can't isolate whether the copier is just a peice of ****, or i just got a bad toner with it. i am guessing.... both.
  • 24 Answers
All that i can suggest is that the machine has not been set up properly, is the tape removed from the toner cartridge?. Has the document feeder been set up properly in diagnostics, you have to turn it on with that model i think. Has the main charge or transfer corona become covered in toner during transit to your site.
11. Check the SPF scanning position switching setting.
• Execute simulation 53-10 (SPF scanning position switching setting)
and check that the setting value is [1]. (If the value is [0], change it to
[1].)
Posted on Sep 26, 2008
  • 446 Answers
Try flipping the paper over, you could be copying on the wrong side of scanner, where the image is upside down.
pls try...cheers
Posted on Aug 30, 2008
Paper jab no paper
Follow the instructions some jams are very hard to see.
Aug 19, 2014 | Sharp AR-M205 Copier
I want sulving this problem call for service. code : u2-40
Here is a list you can find a copy of all the error codes
http://businessneedz.com/Info/?p=282
Seems like a board error. The machines are almost 12 years old now and parts are very hard to come by. You may be able to pick up a used Sharp AR-M205 off ebay or you may want to consider upgrading to a newer machine.
Sharp Copiers
Nov 06, 2012 | Sharp AR-M205 Copier
Whats your price of this machine
The Sharp AR-M205 Copier, seems to be Discontinued. I can't find it anywhere. Although you can still get parts and Toner drums for it.
This place has it. Sharp AR M205 Copier. $1227!! http://www.digitalsystemcopiers.com/Sharp_arm205specs.html
Mar 02, 2011 | Sharp AR-M205 Copier
How to see paper count of Sharp AR-M205
Hi, i suppose you mean the copier meter reading. There are two ways one is for the copies made and the other for prints made. Press and hold # for reading prints made and press and hold 0 for copies made. Read the six digits that appears and record on a sheet of paper as they start and thats the reading. To know daily readings, subtract the figure for evening from the one for morning and the difference is your reading.
Dec 06, 2010 | Sharp AR-M205 Copier
My error message is E 7 flashing. After leaving it off over night it worked for a couple of copies. Now I am getting the same error message E7.
press and hold the copy key the second part of the code will show then go to google and type in "sharp ar-m205 E7-xx"
where xx is the last of the code you should get an answer there
Jan 12, 2010 | Sharp AR-M205 Copier
Both our brand new copy machines SHARP M316 have problem with the
first thsing to check is the side guides for the paper make sure they are set against the paper being fed through if not the paper will be pulled through at an angle and this can cause your problem you can alson get a slightly heavier paper and put that through to see if you have a jam..did you remove all the packing tags and paper protectors
Jun 15, 2009 | Office Equipment & Supplies
My Sharp AR M205 has the error H4
Hello sir; Your machine require reset procedure; press "#", "interupt", "clear", "interupt" then enter 14 press start.
Jun 04, 2009 | Sharp AR-M205 Black and White Copier
Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
Apr 01, 2009 | Sharp AR-M205 Copier
My Sharp AR-205 works fine on copier but the printing is very slow, what should I do?
it copy speed 20 copies per please you buy your requarment coy quantity speed
Mar 19, 2009 | Sharp AR-M205 Copier
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
Sharp AR-M205 Copier Logo
82 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
