Question about Palm Treo 600 Handheld
Trying to hotsync kills the pda
I had to hard reset my pda. after doing that i tried to resync and it ran through the whole process and then imploded - getting stuck in a loop where the only thing happening is the logo flashing every 3 seconds or so....got a new PDA due to other issues and same thing. any ideas?
    Master:
  • 473 Answers
You must have a 3rd party or a driver from a prior different palm os device causing the problem. You will need to rename your C:\Program Files\palmone\Username\Backup\ directory to allow the first sync. It will create a new one. The double click on the files in the old Backup one at a time to determine which one to avoid or reinstall the apps one by one.
Posted on Sep 11, 2005
My computer crashed. I have a backup of all my Palm files but am having trouble recovering them. Does anyone have instructions on how to restore backup files on a Palm Tungsten E2?
Hello.
Palm backups are located in the following directory: C:\Program Files\Palm\username>\ED\Backup\
When you HotSync a PDA that has undergone a hard reset, HotSync will compare the two devices. When it sees that the PDA is empty, it will attempt to reload any backup that exists on the PC. Once this data is reloaded, the PDA will ask to do a soft reset. This is simply a restart of the device and doesn't affect any of the newly installed data. This returns the PDA to working order, with all the data and programs functioning as they were before.
Hope this resolves your problem.
Jan 23, 2011 | Palm Tungsten E2 Handheld
Tip
Visor Deluxe does not start
Hi.
The procedure below shows how to reset the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
To perform a hard reset:
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Connect to HotSync and do a backup of the PDA, then do hard reset on Palm.
If the PDA is not detected by Hotsync, then there is an additional problem.
To troubleshoot problems given by third party application you do a backup, then rename the backup folder containing third party application data to Backup.old, and do hard reset.
After that you start restoring applications from backup.old one at the time, when one application jams the Palm, that is the responsible for the error message.
Procedure is described here.
Regards.
G.
on Apr 09, 2010 | Handspring Visor Deluxe Handheld
Palm centro goes into hot sync mode
IN PREFERENCES GO TO PERSONAL/BUTTONS THEN AT THE BUTTON LOOK FOR HOTSYNC PRESS IT THEN ON CABLE CHANGE IT TO PHONE; IT MIGHT BE THE PHONE HAS A PROBLEM WITH THE HOTSYNC CABLE CONNECTION. NOW IT DOES GO TO HOT SYNC INSTEAD IT GOES TO PHONE. NOW I'M TRYING TO FIX THE PROBLEM BUT MY PHONE STILL USEFUL.
SORRY ABOUT MY ENGLISH
Sep 14, 2009 | Palm Treo 500 Centro
HotSync problem:connection could not be
After you change the battery you need to do a hard reset. This will erase all the info in your pda so you want to make sure you have it all backed up on the palm desktop To do a hard reset follow these steps:
1. Hold down the power button.
2 While holding down the power button, use the tip of the stylus and inset it into the hole in the back of your pda and gently press and release the reset button in the back of your pda.
3. When you see the message that warns you about erasing all of the info on your hand held select continue.
4. When prompted follow the online directions to align the screen. After that you will want to do another hot sync. Best wishes.
Aug 10, 2009 | Palm Tungsten E2 Handheld
When you do a hard reset:
Yes I would remove first
Aug 07, 2009 | Palm TX Handheld
After linking to my desktop and doing a two directional hotsync and installing some software including 'mobipocket' a message ' memorymgr.c,Line:3835, NULL handle' appears. A reset is suggested but the...
The solution is in the same message in which I stated the problem as I hit upon it before I sent the message. It is here for free as I discovered it ' by the hand of the Almighty'. As the pda is rebooting when doing a soft reset try to jiggle the 'on-off' switch off. If nothing happens repeat the process. At some stage the machine should switch off. Now things should be OK. I don't know why it worked for me but I hope it works for you.
Jul 18, 2009 | Sony CLIE PEG-TJ35 Handheld
Pda will not hotsync
assuming that you use your palm tx on a windows xp system, files from the emails could be corrupted. are you using palm desktop or outlook?
if you are using palm desktop, you can rename the back-up folder to old and try to resync
Oct 08, 2008 | Palm TX Handheld
Palm tungsten
you may want to run through a few troubleshooting tricks
first try pulling out any extra USB type items that you remove and replace frequently (like a flash drive) and restart your computer after its done booting up you can try hotsyncing again. Make sure what you wanted to put on your PDA is still in the Hotsync manager box.
A PDA not wanting to hotsync is a very general statement. It is an indicator for many different problems.
-You may need a new hotsync cable
-try a different usb port on your computer
-you could open the PDA up and check if all the contacts are clean and connected (Warranty void alert)
-Try re-installing the PAlm desktop software
-If nothing else works put whatever application you're trying to hotsync onto a SD card and copy it from the card and onto the PDA
Tungsten Es are excellent PDAs and it doesn't have too many problems besides being too "basic". A problem like not hot syncing probably isn't an indicator of something really bad unless you've dropped it too many times.
If all else fails you may need to pick up a different PDA
Jun 19, 2008 | Palm Tungsten E2 Handheld
Palm OS-based PDA freezes up
If you’re not sure what file or application is causing the problem, you’ll need to perform a hard reset. Before you do this, be sure to perform a HotSync so your data is properly backed up (the hard reset will erase all data on the PDA). To perform a hard reset, press the power button while performing a soft reset. Replace the power button when you see the Palm/PalmOne logo and press the Up button when prompted.
Next, find your Backup folder on the desktop. You’ll usually find this folder located within your user folder, which is usually located in either C:\Program Files\Palm, C:\Program Files\palmOne, or C:\Program Files\Handspring. Your personal folder will resemble the user name you selected for your device. If you used your first and last name, for instance, your user folder will likely be the first six letters of your first name followed by the first letter of your last name. Rename the Backup file to Backup.old and HotSync your Palm to restore personal data. Because you renamed your Backup folder, no applications or additional files will be restored at this point. Instead, an empty new Backup folder will appear. Move applications from your Backup.old folder into the new Backup folder one at a time and HotSync your Palm. After each HotSync, try to reproduce the problem. If the problem doesn’t reappear, move on to the next file. Delete any files that cause a problem after they are moved onto your PDA.
Enjoy! Pls.rate me if it's done. Thanks.
Kindly regards,
-micro
Feb 29, 2008 | Best Software ACT for Palm OS - Instantly...
Palm Treo 600 Handheld Logo
26 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
