Question about Kenmore 43042 Front Load Washer
Kenmore washer I saw your post on the FixYa.com in 2006. I am wondering if you may know how to open a front load washer. My machine appears to have a very loose drum and make loud noise. Thanks. JoeJae
  • 5 more comments
  • JoeJae Aug 30, 2008
    Ok, this is a Kenmore front load washer, about 6 years old. The model # is 417. 42042100, serial # XC21911028
    The machine makes huge noise when spin and make above normal noise in wash cycle.
    I use my hand to touch the drum, and can sway the drum easily. Obviously the drum is loose.
    thanks for your quick response. I just found my washer manual and was thinking I get what I need, I will refer you manual and may come back with questions.
    JoeJae
    I guess the topic may have been entered in the wrong category?
    My washer has a flat top such that a dryer can be stacked on top of it.
    Could you please let me know how to take the entire drum out and inspect the bearing? I guess to do so I will have to open the shell (encasing the drum) which is heavy and hung to the cabinet through two springs.
    --JoeJae
    Not hearing back from you... I watched the video but they are not helpful to my problem. My washer is front load, and the drum is loose, how do I take apart it and inspect what needs to be replaced?
    Can you please tell me why it is related to the motor or electronics? Based on my observation, the drum is loose. When I spin with my hand, I can hear the noise between the drum and its housing body.
  • JoeJae Aug 31, 2008
    Ok, I think I finally find a clue on the internet:
    The Kenmore front loader was designed by Electrolux (Frigidaire), with 417 in the model #.
    The design appeared to be problematic. Check the thread here and watch the video inside, and you would know for god's sake, the failure might be on purpose!?
    http://www.appliancejournal.com/applianc...
  • JoeJae Sep 01, 2008
    Hi Coolguy,
    Thanks for your kind answers. I did spend a few hours watching all those videos (40+) but there were not a lot helpful to my issues. I did google search and ended up know the issue better -- refer to the link I posted in my prior post. Someone there even wrote the step-by-step guide to show people how to disemble the machine, exactly what I need. People be aware, if you get a broken washer -- most likely it is designed to fail!
    I don't see anywhere I can rate the answer -- other than the button to "accept the solution".
    Genius:
  • 1,847 Answers
Remove the lower access panal on the front and look for an envelope....the envelope will contain the tech sheet to test the motor, motor electronic control board and timer to see if the problem can be narrowed down....will appear to have info like this...
Posted on Aug 30, 2008
  • Legin Varghese
    Legin Varghese Aug 30, 2008
    http://appliancehelp.hypermart.net/newpi...
    Genius:
  • 3,422 Answers
HI,
You can check out this video:
http://uk.youtube.com/watch?v=UuBeREGbGQ4
  • 3 more comments
  • Priya darshan Aug 30, 2008
    Just click on the link which i gave you
    On the right side you will see more videos
    Did you watch all the videos?
  • Priya darshan Aug 31, 2008
    You will have to replace the bearings.Try to spin the drum with your hand if you still get the noise then its time to replace the bearings.
    If you need anymore help let me know.
    Please don't forget to rate or accept the solution as fixya.
  • Priya darshan Sep 01, 2008
    OK,
    Please click on accept solution.
    Let me know if there is anything else i can help you with.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Suds and F2 error keep appearing the machine will not finish a complete wash cycle
Hello, welcome to fixya. Based on your post I understand you have suds and a "F2" error problem with a Kenmore washer, the error means an excessive drain time or excessive suds was detected as you may or may not already know. If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is) http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds Thank you for visiting fixya for your washer inquiry. Please take a moment to rate my assistance both here and on my tip link and leave a brief testimony. Regards, Macmarkus :)
Jul 06, 2011 | Kenmore Front Load Washer
Final spin cycle doesn't wring out, does not appear to be spinning, a slight burning smell.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 08, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Front Loader Washer Doesn't Drain
heatman101
May 25, 2010 | Kenmore Elite 45986 Front Load Washer
How do I remove the pump from a kenmore 70 washer?
The Kenmore 70 series is a top loading washing machine. Different from the picture you have this listed under. If this is a Kenmore top loader, the following link explains how to replace the water pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this is a front loading Kenmore, the next link applies:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you have any questions about this repair, or if you require additional assistance, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Front Rubber Washer
Here ya go. Follow the steps outlined in this link:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have questions along the way, please let me know. If you need to know where to purchase a new door seal, also let me know. Post back with your model number for clarification. I hope this helps you.
May 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loading Washer started vibrating wildly.
Here is a website that outlines what your problem might be. I had the same problem yesterday after owning my Kenmore tumble washer since July, 2003.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Feb 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
F11 flashing kenmore he washer
The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore he5t
this looks like a classic whirlpool control board issue. fault is a communication error between board and panel. check connections.
whirlpool always recommends replacing both at same time. very common problem.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 43042 Front Load Washer Logo
75 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
