Question about Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Intermittantly I get a blue box popping up in top right corner of the TV Screen showing Cable - Analog 8 and then Audio - Mono (sometimes in red text sometimes in green text) and then sometimes it switches and shows Audio Stereo - and there is a buzzing noise. Appears to be an uneven audio signal. Time Warner says it is the TV. Sharp denies any sound issues/problems with their TVs but I am seeing a lot of problems posted.
  • 14 more comments
  • callkat Aug 30, 2008
    Thanks!
  • redterrorz Sep 12, 2008
    i have same issue w/a Sharp 46" LCD
  • yarnat00 Sep 22, 2008
    I have the same issue. Is there a way to prevent this display box from popping up regarding the switch between mono and stereo? It is very distracting.
  • Anonymous Oct 04, 2008
    I have a sharp lc-37sb24u and it has the same problem. try www.sharpusa.com and see if there is a firmware update for you tv's. Mine isn't even listed.
  • desertkat12 Nov 22, 2008
    I have the exact same problem and we bought the TV 1 day ago, very frustrating, there is no help in the owner's manual whatsoever
  • Reginaoc Nov 30, 2008
    We have the same problem. Please when you figure out how to fix it we would be greatly appreciative. Thanks.
  • Anonymous Dec 10, 2008
    I've got the same thing Sharp 32" LCD... got solution?
  • Wren07 Dec 19, 2008
    SAME PROBLEM! Sharp has to understand that this is a problem. We need to see if we can point a Sharp tech to this forum to read the comments.
  • laughinggirl Dec 20, 2008
    Mine is switching from stereo to mono also, with the blue box popping up. I tried to email Sharp about the problem with no response. It only happens on a few channels but they happen to be my favorites!! ANNOYING
  • kyle_hall25 Dec 22, 2008
    i have the same problem with my lc32sb21u
  • boo_girl2 Dec 27, 2008
    I also have the same problem with the Sharp LC-32SB23U. Hope somebody knows what to do.
  • rjk3810 Jan 19, 2009
    I have the same problem. Blue box in right corner of the screen. Nothing in the manuel shows how to turn it off. Anybody have a fix?
  • cambriabries Jan 21, 2009
    We got this TV 2 weeks ago and have tried every setting to fix it. Nothing... I am switching to a new HD box from Comcast in a week or so.
  • JuCrowley Apr 03, 2009
    I have the same problem - 42D64U - It's SUPER annoying and there is no fix to it. All my other TV's work just fine on the same jack - it's obviously a Sharp issue.
  • Anonymous May 06, 2009
    I have the same problem and have tried different settings and can't figure it out. Would like help.
  • Kim Gillespie Apr 17, 2012
    I have a sharp aquos 40inch HD TV that also has intermittent sound problems only on certain channels. Trying to watch certain channels and having the sound go off and on is so annoying. My husbands TV has no problems with any channels but is a Visio. I have been fighting with Sharp about this for 2 years now and they don't seem to be concerned. They say it's the cable. The cable has been replaced throughout my house and from the pole into my house. They did try to switch the main board of the TV but it didn't help. Just cost me $160.00 for nothing. I know I will never buy another Sharp.
Yes removed old cable box & its fix it . Thank now its time for Hi-Def boxes .
Posted on Jul 09, 2009
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Posted on Jan 10, 2009
HOW DO I GET THE BLUE BOX ON MY SHARP AQUOS LCD TV TO STOP POPUP
This happens when you are connecting with a coaxial cable. If possible you will need to connect your set top box to the television with a composite/RCA cable and watch tv on input 2 instead of on input tv.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
My new sharp LC-52D65U tv continuously gives the sound display on the top right hand corner when it switches from mono to stereo etc. It dosn't do this all the time but for a while it will start again.
Make sure it isn't the source causing the problem. I.E. Cable box, dvd player, xbox or ps3. Try switching the wires. If all else fails, replace the main board.
Dec 05, 2009 | Sharp Televison & Video
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Sharp LCD tv "Audio window" keeps popping up on the corner
Replacing the cable box may fix the problem. But, you're the 4th person to have this same problem with this SHARP TV MONO only audio.
Try system reset button on the back of the TV or the box.
Feb 17, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Jan 25, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
DIsplay box with keeps popping up-
I sent an email to Sharp and they answered
Dec 30, 2008 | Sharp Aquos LC-32D40U Television
Stereo/Mono Fluctuation Screen Display Problem
I had the same problem.
All I did was unplug the standard cable wire from my tv and used RCA cables to connect my TV to my digital cable box the the Input 1 jack in the back. It also increased the video quality.
Aug 07, 2008 | Sharp LC-42D64U 42 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Aquos Channel Bar/audio bar
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Jan 12, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32GD4U 32 in. LCD HDTV Logo
1,782 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
