I would like to replace or clean the waste absorber pads on a i550 Canon printer.Do you know the technique?
    Sergeant:
  • 293 Answers
Well to be perfectly honest you can try to clean them but replacing them is pointless, and near impossible because the parts aren't available seperately from the printers, nor will Canon send you replacements. It would probably be cheaper to just buy a new printer. I'd suggest spending a little extra cash on a personal laser printer instead. No need to worry about an waste receptical.
Posted on Aug 30, 2008
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Waste ink absorber full
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 04, 2008 | Canon Office Equipment & Supplies
Tip
How To Reset Ink Absorber Canon i550
When your Canon i550 printer get an Ink Absorber Full error, then you need to reset this Canon i550 inkjet printer.
The following step is procedure used to reset waste ink counter of Canon i550. Nevertheless, this procedure is also applicable for the printer models listed below.
PROCEDURE:
I. Enter Service Mode:
  • Plug in power cable
  • Hold down RESUME/CANCEL button
  • Hold down POWER button
  • Release RESUME/CANCEL button
  • Press RESUME/CANCEL twice in a row
Continue reading complete step below:
How To Reset Canon i550
on May 11, 2014 | Office Equipment & Supplies
Tip
Reset Waste Ink Absorber Canon i550
The following procedure is used to reset waste ink counter Canon i550.
PROCEDURE:
II. Execute Waste Ink Counter Reset operation:
  • Press RESUME/CANCEL button 4 times in a row
  • Turn off the printer by pressing POWER button
on Jan 03, 2010 | Office Equipment & Supplies
Waste ink full?
GET YOUR PRINTER SERVICED AND CLEANED
VOTE AND GIVE ME ALL THUMBS
PROUD TO B AN INDIAN
AND PROUD TO BE A PUNJABI
Jan 28, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Canon
hi i am a certified Canon repair tech for this printer. the flashing lights indicate a error code. what this one stands for is that the waste absorber pads in the bottom of the machine need to be replaced and the error code reset. this should be done by a service center it is very messy. to locate a service center for your machine you can call 1-800-OK-CANON and they will help you find the nearest one. hope this helps.
Dec 29, 2007 | Canon BubbleJet i550 InkJet Printer
117 people viewed this question
jasbo
jasbo
