Question about Smeg WDI12 Front Load Washer / Dryer
Washer/Dryer is not spinning
Hi there, my Washer/Dryer is not spinning and clothes are coming out soaked. It makes a noise like it is spinning but when I watch the drum is not turning.
  • 639 Answers
Friend,
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to the drive of the agitator is worn and needs to be replaced.Similar to the drive shaft of a rear wheel drive v-8 car!
Could make this sound first, like a knock,knock,knock or klack, klack,klack
OR,SOMETIMES JUST NO SOUND AT ALL AND JUST NOT CONNECTED FROM THE TRANSMISSION TO DRIVE THE ROTATION OF THE TUB!
This means you need parts! and service!
How old is the washer if it is 10 years old or more I recommend being prudish about investing a lot of money in to it!
The newer models are so much more energy efficient, that they save you water,gas or electricity And detergent too!
They can pay for them selves in energy savings in a few years!
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 30, 2008
Hi my whirlpool doesent speen
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will notturn - 11068202794. ApplianceVideo.com ...
Kenmore / Whirlpool Washer Not Spinning 1 - YouTube
? 11:33
https://www.youtube.com/watch?v=TB_W6sPdzkM
Jul 10, 2012 - Uploaded by Bill Newberry
Kenmore / Whirlpool Washer Not Spinning 1. Bill Newberry ... Washer will not spin the clothes dry ... Now ..
Dec 03, 2015 | Whirlpool Dryers
Kenmore 80 series washer leaving clothes soaked after the spin cycle
In order to fix this, you will need to take off the outer panels and check the motor inside and the clutch, most likely the clutch is worn down and will need to be replaced, I have posted a picture of what it should look like.
Please let me know if you have any other questions or need further help, most likely replacing the clutch will solve your problem.
Good Luck and thank you for using Fixya
Apr 24, 2008 | Dryers
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
MY DRUM IS VERY LOOSE ANY IDEAS.MY CLOTHES AFTER WASHED WAS STILL SOAKED.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Jul 06, 2011 | GE WCVH6260FWW
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Smeg WDI12 Not Turning + can't get into it!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 26, 2008 | Smeg WDI12 Front Load Washer / Dryer
Smeg WDI12 Front Load Washer / Dryer Logo
390 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
Jorge Rendon
Jorge Rendon
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
