Question about Kodak EASYSHARE CD33 & Printer Dock Series 3 (Pack) Digital Camera
Easy Share printer Dock series 3
Recently the printer dock, which up to now has printed photos perfectly, only prints half of the photo- it cuts off the top portion. I recently replaced the cartridge, but it has not corrected the problem.
  • 2 more comments
  • Amorita Nov 06, 2008
    mine does exactly the same
  • cbartusch Nov 30, 2008
    Sorry I didn't have a solution I hit the wrong key
  • swimcoach1 Nov 30, 2008
    I have the same problem
  • animalsaver2 Mar 05, 2009
    I have the same problem! It used to print beautifully now it's only 1/2 a page. I changed the print cartridge twice and used a new set of sheets to print, cleaned rollers, etc. but it still continues.
  • 31 Answers
The problem is most likely a broken plastic lever on the end of the shaft that moves the print head. The plastic lever is keyed to the shaft by a flat on the shaft. The plastic has a tendency to split at the edge of the flat, resulting in the lever slipping on the shaft. This in turn results in one side of the print head not contacting the paper with sufficient pressure. The other end of the shaft has a thick plastic sector gear which is much less likely to break.
I fixed mine by making a clamp from a metal spacer (made from split tube about 1/8 inch long) and force fitting it over the part of the plastic lever that fits on the metal shaft (on the end towards the inside of the unit). There is just enough clearance to do this without hitting the print head frame.
To remove the plastic lever, first remove two screws from back of unit, then pull up on top of unit, unplug two ribbon cables from circuit board and remove top. Then unplug two remaining ribbon cables from circuit board, and three screws holding circuit board. Lift circuit board and fan/fan-holder as one piece. Finally, disengage tab on plastic retainer on end of metal shaft, rotate tab straight up and lift shaft up and to the side (may require a little wiggling). The plastic lever slides off the metal shaft.
Posted on Mar 20, 2009
  • gzuraski Mar 22, 2009
    If the boundary between the blank half and the printed half is a sharp line, a wire to the print
    head may be broken or disconnected. If the boundary is irregular
    (wanders up and down an 1/8 inch or so), the problem is most likely a
I have the same problem with my printer dock as peif-4 who posted on Aug 30,2008
I have changed the ink cartridge and clean the rollers and as much as I could, this set encluded the camera C530
Nancy
Posted on Nov 30, 2008
My easy share printer dock series 3 is having a paper jam at every photo and only printing half of the photo
please make sure you're using Kodak Xtralife paper - check the back. paper jam and print quality is affected if a different kodak paper is used.
Jul 08, 2009 | Kodak EasyShare One Digital Camera
Easy share printer dock only prints half of picture
You have to go to printers & faxes on your "start" button on your computer screen. And click properties on your printer. And fix the alignment size of picture printing. Or your out of ink.
Jun 03, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
Printer dock does not pick up paper.
Try to clean the rubber rollers with lint free cloth. Make sure you are using Kodak Xtralife paper. At the back of the paper it should say "Xtralife".
Apr 02, 2009 | Kodak EasyShare Thermal Photo Printer
Kodak dock series 3 printer
Sorry for the delay hope this is not too late. I was able to fix mine without removing the cam or the rod.c0b30ab.jpg7d99504.jpg
Nov 07, 2008 | Kodak Dock Series 3 Laser Photo Printer
Well it's not looking to pomising by reading all of the other people who are having the same problem. But could you please tell me how to fix my printer in is only printing half of my pictures no matter how many times i reprint them and it also doesn't pick up the printing paper very well i have to help it along. So if you could PLEASE tell me how to fix this problem on my own it would be greatly appreciated. Please respond As Soon As Possible Please and Thank You. I have the Kodak Easy Share Printer Dock Series 3.
Patricia Davis
Nov 03, 2008 | Kodak EASYSHARE Printer Dock Thermal Photo
Easy share kodak dock 3
Yes you can, but you need an appropriate USB cable----takes a regular USB type A on one end and a USB type MINI B (but NOT MICRO) on the other end. Kodak has one for 25 bucks. Stop at your local WalMart and pay 15 bucks or order it from Walmart.com for under 5 bucks (plus shipping of less than 3 bucks):
http://www.walmart.com/catalog/product.do?product_id=4810462
Just got a cable for similar use myself......Happy printing.
Sep 22, 2008 | Kodak EASYSHARE Plus Series 3 Thermal...
Image prints on one side paper,kodak printer dock plus I have a printer dock that only prints on the bottom half of the photo paper. This dock is for a C533 Didgetal camara. Please help.
did you try to change the orientation to landscape or portrait? you can also check the printer properties and make sure that you have the right size paper selected
Aug 20, 2008 | Kodak Dock Series 3 Laser Photo Printer
Cameras Logo
203 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
