The sound gets worse until it sounds like it's slowing down and then just stops. It seems to be when the tub goes back and forth. It spins just fine all other times.
Friend,
ngfam1 At your service!
Sometimes this can happen when the connector from the transmission to the drive of the agitator is worn and needs to be replaced.Similar to tyhe drive shaft of a rear wheel drive v-8 car!
Could sound like a knock,knock,knock or klack, klack,klack
If so here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
This needs to be repaired by a trained laundry mechanic!
And if its an old machine you have to decide if it's worth investing good money in to bad.(Bad being 9 years old or more)
AND if it is a transmission replacement needed , I would cut my loses,
And throw it out! you will hate your self if you spend a couple hundred for a transmission and the have something else go after that!
How old is the washer?
Is this not a problem I can fix myself?
It's at least 5 years old and we're moving to Germany in October (USAF). Sounds like we need to get rid of it. Thank you for your help.
