Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Bulb is out
I bought a replacement bulb and there is no installation instructions.
  • 85 Answers
First unplug the AC feeding the set look in your owners manual for location of lamp door cover you may need a flat head screw driver. After locating the door and lamp it is just remove old lamp and firmly install new one do not get finger smudges on new lamp or try LG for help on line an online search for their customer website there you should find instructions to replace lamp
Posted on Sep 26, 2008
2 Suggested Answers
  • 42 Answers
SOURCE: 915P043010 have the bulb
Pull the panel off where the speakers are the entire plastic lover comes off. Next, make sure the tv is unplugged and has been off for at least 15 min, preferably longer. See the box with 4 screws take those out... it should have a set of instructions or some sign saying it contains the bulb. Anyway.. after that door comes off, peer inside and you'll see the bulb about 6-8" back and has set screws which must be unscrewed completely before it can come out. Be careful, don't yank the bulb out. Then place the new bulb in, reverse the process I told you, plug the tv in and reset the bulb when it askes if you changed the bulb.
It is really easy on mitsubishi tv's to change them... post back if I can be of further assistance.
Posted on Mar 12, 2008
Replacement bulb not working on HP vp6121
The ballast board controls the bulb. It is the board with the wires going to the bulb socket. Replace that and you'll have a working projector.
Jul 23, 2016 | HP VP6121 DLP Projector- XGA 2000 Lumens...
How do I replace the headlight assembly MN133516
The 2003 Outlander utilizes replaceable (9007) headlight bulbs. If you're looking to replace the bulb(s);
1. Raise the hood.
2. Remove the plastic cover at the rear of the headlamp assembly by rotating it counterclockwise, and pulling it off. This will allow access to the headlight bulb.
3. Twist the bulb socket counterclockwise in order to remove it from the headlamp assembly. Pull the old bulb out of the socket, and use a clean cloth to install the replacement bulb. Do not touch the glass of the new bulb.
4. Place the socket back into the assembly, and twist it clockwise. Reattach the plastic cover, and close the hood.
Are you needing DIY instructions for replacing the entire headlamp assembly? Left (driver) or Right (passenger)?
Jan 18, 2013 | 2003 Mitsubishi Outlander
How do I Replace light bulb in bernina 1010
Theres a gray flexible cap about 1.5" long and .75" in diameter that comes with the machine. It is used as a tool to screw and unscrew the bulb. Weirdly I have had my machine since I bought it new in about 1987 and have never replaced the bulb. And I do use it, at times heavily.
Aug 17, 2012 | Bernina Sewing Machines
Can I install a utilitech Dusk-to-Dawn light control, #0314355 in a 'horizontal' position, rather than the 'vertical position shown on the packaging? It goes 'on-and off' in a 15 s
Timer is probably wired incorrectly.
Copy following links for correct wiring, and larger instructions.
I have tested this timer, and some problems can also be caused by overlapping and conflicting programs: reset timer and review timer instructions:
Jul 31, 2012 | Hardware & Accessories
Bulb is dead on passenger headlight i purchased bulb but not sure how to replace
If you didnt know how to replace it, you should not have bought one. Most auto shops will not install parts not purchased from them. Its not a big deal to replace the bulb, just look at the rear of the housing and there wil be a cover and a ring or clip holding the bulb in. Be sure to NOT TOUCH the bulb with your fingers.
Dec 01, 2010 | 2006 Toyota Sienna
The light bulb of my Sony KDS-50A2000 busted, I bought a new bulb and I need instruction/procedure to replace it.
Operational manual has instructions about lamp replacement, click Sony Support to download copy, if required and check page-51 for detailed info.
Sep 08, 2010 | Sony KDS-50A2000 50" HDTV
Fender bender, bought new assembly. How to remove old for replacement? "89 seville driver side headlight.
  1. Unscrew the Torx retaining screws and remove the headlight bezel.
  2. Remove the headlight bulb retaining screws. These are the screws which hold the retaining ring for the bulb to the front of the car. Do not touch the two headlight aiming screws, at the top and the side of the retaining ring (these screws will have different heads), or the headlight aim will have to be re-adjusted.
  3. Pull the bulb and ring forward, then separate them. Unplug the electrical connector from the rear of the bulb.
  4. Plug the new bulb into the electrical connector. Install the bulb into the retaining ring and then install the ring and the bulb. Install the headlight beze
Aug 23, 2009 | 1989 Cadillac Seville
Replace turn signal bulbs on 2001 corvette
Rears are simply remove the two screws on the lens and remove the tail light from the Vette, twist the connector to get to the bulb. Reverse instructions to install. For the fronts jack up the front, remove the small closeout panel under each side, push the brake cooling duct to one side and twist the bulb socket out of the light to get to the bulb. Reverse instructions to install.
Feb 22, 2009 | 2001 Chevrolet Corvette
Headlight installation instruction
normally raise hood look behind the light that outt is some has a socket you can turn to left or right and the bulb will come turn bulb right or left replace new bulb then replace socket back into head light
Feb 08, 2009 | 2001 Nissan Maxima
Replacing Fujitsu lamp
I suggest that you should refer to your manufacturer/ store owner that you bought that bulb and your scanner as well for you to installed it properly.ok?
Trust me, I don't want you to lead from errors and accidents =)
Jan 15, 2008 | Office Equipment & Supplies
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
105 people viewed this question
Computer Repairing
Computer Repairing
