Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series power nozzel
I need someone to tell me where i could buy a rainbow e series power nozzel..please help
  • Rainbow Expert
  • 324 Answers
Check it here
Posted on Nov 19, 2008
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
How do I attatch the power nozzel to the e series rainbow vaccuum? it seems there is cord attatched to the nozzel : I can't figure out where this plugs in??>?
One of your hoses also has a cord that goes the length of the hose. Up at the handle end the cord goes to your handle. At the end that plugs into the unit, the cord plugs into the unit just under the hose hole. You should also have a hose with no cord that is used with the bare floor brush and other attachments.
Feb 10, 2015 | Rainbow Vacuums
On a rainbow d4c there is what looks like a capacitor. it is mounted close to the power nozzel recepical. it has two wire attached to it. I need a new one but haven't been able to locate. Can someone
Does the power nozzle have a motor in it. If it does the capacitor is probably an interference suppressor type. Is it a square / oblong cap with 2 leads? If it is then you need to look at it and find the capacitance value and the voltage. In the UK it is something like 0.1uF / 250 Volt (or higher). Some have 3 leads, 2 go to the motor power leads and the other is an earth connection. If it's a cylinder type then it will probably be either a mains filter cap or a motor start cap. Either way you should be able to get one from electronic component suppliers or even Ebay. As long as you can get the info off the original cap.
Dec 15, 2014 | Rainbow Vacuums
Shampooer will not work on my e2 Rainbow. Help!
Your Rainbow E series has lost suction power, because you need a new hepa filter, or your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If it is an earlier model, everything applies, except for the filter. They do not have filters, on any of the earlier models.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Jan 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
My Rainbow Power Nozzel will not **** up things
Check your belt and make sure your brushroll is good.
Oct 20, 2009 | Vacuums
Rainbow e series musty odor
The unit and the nozzle have to be taken apart and cleaned. You almost for sure will need a new HEPA and possibly even the motor cooling filter. There is a lot of dust inside that got moist (moisture in the air,vacuuming wet carpet, maybe you have pets or everything together)
It will require a bit more advanced skills but you do not have to be a vacuum repair professional to do this.
Sep 18, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow e series Canister vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=661549
Posted by tinyrose on Jun 10, 2008
I am looking for a repair manual for this vacuum. Just stopped working and will not turn on. Can you tell me where to get a manual? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The best way to get a Rainbow E Series owner’s manual is to contact the Rainbow website and or factory and give them the model and serial # for the item and you may be able to download the manual from the website or the might have to mail it out to your home USPS. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E-series Aquamate II connection problem
Well I am not goinmg to call, but you can go to http://www.rainbowsystem.com/manuals/
And download the manual for your model of Rainbow.
Feb 28, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
198 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
