Question about Palm Zire 72 Handheld
Hot sync does not work
When I try to hotsync my palm to my pc to update MS Outlook no data transfers. I get a message in the activity log that says "Please set the option "Enable synchronization when Outlook is offline" in UI in order to synchronize in offline mode. What is "UI" and how do I find it to do this enabling?
    Master:
  • 473 Answers
"PLEASE SET SYNCHRONIZATION OPTION ENABLE SYNC WHEN OUTLOOK IN UI IN ORDER TO SYNC IN OFFLINE MODE" Just go to your Hotsync Manager icon Click Custom Click each Outlook conduit ex. Calendar Outlook Click Change Click Settings Check the Box that says Enable Synchronization when Outlook is Offline Then do same process for Contacts, Tasks and Memos. Wherever your updated data is..make sure you set Action of conduit to example: Desktop Overwrites HH (if your OUTLOOK has the most updated data.) Hope that resolves your problem.
Posted on Sep 11, 2005
My software was corrupted in my desktop. I have all the information in my laptop and also in my handheld.
I cannot get the sync to work in either my handheld to my laptop now or to get my information back my desktop. I reinstalled the software onto my desktop but it will not work.
Posted on Mar 22, 2008
It works-- thanks for a straight answer
Posted on Feb 02, 2008
SOURCE:
Manual Hot Sync
If u need to make connectivity between computer and Palm mobie then u need to install hot sync software on ur Pc and activate hotsync option from ur mobile then with cable u can transfer the data . if u  not have proper software of hotsync then download it from palm Site.
Gizmo1
Oct 22, 2007 | Palm LifeDrive Handheld
Unable to sync with outlook 2003
Try to change conduits to hotsync with PDS, if it will work then the problem is with the MSOutlook.
Sep 12, 2005 | Palm Treo 650 Handheld
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Cannot SYNC Outlook Calendar and Contacts
Probably one of these issues - your data is there but you are looking in the wrong place. I am trying to sync my outlook calendar and contacts via Hotsync on a Palm IIIc. It gives me the status of OK, but nothing shows up on the Palm. I have set the custom on Hotsync to desktop overwrites handheld, but still will not work. Thanks.
Sep 11, 2005 | Palm IIIc Handheld
Hotsync Outlook with domino connector?
It's probably looking for names.nsf on your pc. Try c:\lotus\notes\data\names.nsf or search for it. The fact that it can sync email without error tells me that it's NOT looking for your id file (name.id). There's a slight chance that it's looking for your notes.ini file (c:\lotus\notes\notes.ini) on your pc.
Sep 11, 2005 | Palm Treo 650 Handheld
Update to MS Outlook 2003 causes Hotsync error
delete local user name in desperation, after removing the user name from the handheld and still not getting any results or ANY syncs, I launched Chapura Settings from My Desktop, deleted my user name, re-created my same user name, same spelling, and then everything worked first time every time. I have the latest Pocket Mirror PMStdUpdate3171.exe loaded on top of what came on the installation CD. to sum up, I deleted the user name from both handheld and PC and recreated it only on the PC, then sync'd with outlook 2003 without even a reboot. good luck
Sep 11, 2005 | Palm m130 Handheld
How do I switch from HotSync with Palm Desktop to HotSync with Outlook?
I have a T5 and assume it's the same, but try putting your software install disk in your new PC at work. One of the options is to change sync with Palm Desktop and Outlook.
Sep 11, 2005 | Palm m505 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
How do I update my palm with outlook???
1. make sure Outlook is running on the PC 2. make sure hotsync is running - right click on the hotsync icon in the system tray - click custom - set all the things you "want" to sync and setup the way you want them (i.e. handheld over rides PC, they both sync, etc) 3. have VersaMail configured and setup as well...that's where your Outlook mail will come from 4. Push the hotsync button on your cable/cradle This should get you started. If I missed a step, it should be obvious in the Hotsync log, so check the log after doing a Hotsync.
Sep 07, 2005 | Palm Handspring Visor Platinum Handheld
Palm Zire 72 Handheld Logo
416 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
