Question about Palm Treo 650 Handheld
When I hot Sync my Treo 650, my tasks hot sync fails
Any help?
    Master:
  • 473 Answers
I've been having a problem that sounds similar to yours -- my 650 hangs on Tasks every time I HotSync, forcing me to kill the sync with Task Manager and reset the handheld. If you're still having the Task Syncing issues, you might try the stuff I posted here: http://forums.palmone.com/pe/action/forums/displaypost?postID=20221552&returnExpertiseCode= Under the "Solution for Hanging Conduit Problem" answer
Posted on Sep 11, 2005
    Master:
  • 473 Answers
I changed so that the desktop over-rides the handheld and the hot sync went through. This is not the way I perfer this, but it worked. I have not switched it back to sync the files yet to see what would happen.
SOURCE:
Cable hot sync is always not going through
I had the same problem on the connection and it turned out just to be so simple as some dust/dirt in the connection surface for the sync cable. I fixed it by cleaning the connection surface with isopropanol. That helped.
Nov 11, 2008 | Palm Treo 650 Handheld
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Treo 650 Sync w/ Outlook 2003
Please try the following: 1. Pop the Software Installation disk that came with your treo into your pc and allow it to autoplay. 2. After the disk begins playing, you will be prompted to choose your language-do so. 3. After a second a new dialog box will appear-Select the option "Change your syncronization method" 4. Select "Use Microsoft Outlook to manage Calendar, contacts, tasks and more. 5. Perform a hotsync 6. Open your versamail and hit the sync button
Sep 19, 2005 | Palm Treo 650 Handheld
Original sync worked all others failed with 650 and Outlook 2003
I was ready to give up completely. Uninstalled, reinstalled, nothing worked. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now. This worked for me. I hope it helps with your errors.
Sep 12, 2005 | Palm Treo 650 Handheld
Was there another solution?
I tried the conduit updater with no success--I wouldnt bother doing it.
Trouble sync'ing with two computers
Hiya, I manage to sync with both home and work, I upgraded to a Treo 650, and sync'd at home, then deleted my work user, and sync'd at work... and it's worked fine. I'm able to add tasks, events, apps etc either at home or work, and they successfully sync with the other machine. The only issue I've had is once or twice, my photos have doubled up, but that hasn't happened often. hth David
Sep 11, 2005 | Palm Treo 650 Handheld
Hot sync Outlook 2003 business contacts and accounts to Treo 650
Thanks to a fellow user, I was informed that I needed to purchase Chapura software. The following link has the software that does two way sync with BCM. Others don't. I did however have a few problems, but the help desk through Chapura was able to get the process working. Good Luck.
Calendar Sync issues with Treo 650
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
Palm Treo 650 Handheld Logo
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
