Question about Alpine Car Audio & Video
I have an Alpine X001 and people I call report a serious echo from the bluetooth function when calling them on my phone. My phone is a 1st gen iphone.
    Champion:
  • 232 Answers
Use some higher quality rca jacks
Posted on Aug 30, 2008
How to eliminate callers getting a feedback echo through my stock bluetooth car stereo?
this happened to me in my truck (sounds as if your talking in a tunnel) what it turned out to be was i did not set up my phone on bluetooth properly (mute interal microphone on bluetooth) but i first noticed a sort of fix for this as i put my phone inside my lunchbox oneday and the echo went away on next call , but after looking into it i saw the mute function on phone bluetooth set-up
May 13, 2014 | 2009 Acura TSX Tech
H1! I have an X001 and an iphone.....everytime I shut my car off I lose my bluetooth connection and I have to re-establish my connection every time I get back in the car... Any ideas?
Are you using a bluetooth box? The bluetooth box will lose power when car is shut off as it is directly connected to the ACC (ignition) lead. I am going to paste the diagram here, but if it doesn't work and shows the big red X, I will follow up with a separate comment.
Please verify if this is the manner in which your system is wired, and we will work from there... Thank you!
Jul 05, 2008 | Alpine Car Audio & Video
Cant play ipod after iphone upgrade to ios4.2.1
Check with Alpine for and update for you radio
Feb 16, 2011 | Alpine iDA-X001 CD Player
Poor sound quality via Bluetooth mic after switch to iPhone 3GS
Unfortunately, solution is NOT free. Until Apple decides to take good look into this issue, you are left to buying another BT headset model.
I got lucky first time around, bought new Plantronics (not Playtronics...) Voyager 520 (I do love Plantronics 3xx design, this is the next best thing). It did cost almost twice as much as my previous headsets (about 45 EUR), but it's still on the cheap "side" and (to my experience) also the best value.
Hope new headset also lasts almost whole week before needing recharge, like my "old ones". :)
Aug 26, 2009 | Apple iPhone 3G
Cant connect my ex 10 to my x300 head unit
Hi Jared,
The EX-10 was never intended to be an accessory to the IDA-X300, but should work with FM modulation like any other radio, by making sure the FM frequency is set the same on both units. There are four preset channels in the EX-10 but you can change each one to any frequency.
As for the bluetooth mic connection, you must have that connected for the bluetooth to work. You are better off installing a KCE-400BTi handsfree kit to get better functionality, increased phone compatibility, increased audio quality and the ability to use all of the newer iPods (Gen 2 iTouch, Gen 4 Nano and iPhone 3G).
Hope it helps,
Marcel.
Jun 21, 2009 | Alpine eX-10 iPod Controller with...
Alpine ida-x001 volume is low even if stereo is turned all the way up only when ipod is plugged in on ipod setting.Radio (AM/FM) is normal volume (louder)..How can I fix this?
Most newer car receivers have a feature named something like "level balancing" in which you can adjust the relative loudness of each input (Tuner, CD, AUX, IPOD). Check you owner's manual for a similar function.
Also, are you or can you turn the level of the ipod itself up a bit?
Mar 07, 2009 | Alpine iDA-X001 CD Player
Alpine IDA-x100 and KCE-300BT
Hi
what you need to do is to start off make sure both units are powered from the same point you will see why below. Make sure you connect the Audio Interrupt out lead (pink/black) from the 300bt to the x001 INT IN pink/black wire
Go to general settings turn off the int mute setting, (you proberly have it turned off already the reason your not seeing it) try resetting it using the small button behind the face plate. This should allow you to see the int mute setting. Go to the bluetooth settings and select adaptor. Disconnect power to both units. ( you will need to re apply power to both units at the same time) after around 10mins. when you re-connect the power make sure ALL bluetooth units around the car are turned off. You should now have success in pairing the phone and having the X001 recognise the 300 bt.
Feb 20, 2008 | Car Audio & Video
Caller gets echo of own voice wnen using bluetooth
Because this GPS was manufactured really bad is why that happens.
Before its too late I'd get a refund right NOW!
You are 1 of 5 other 660 GPS problems.
The only GPS problems are the same 660s
Hope this helps - Josh
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
BT pairing code
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Car Audio & Video Logo
49 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
