Question about XION Onyx (XON-301P) ATX Case
Light on Front of Case
The lightstrip on the front of the Xion Onyx case is not lit up. How can I fix this?
  • 326 Answers
Looks like the cable for the light isnt plugged in, turn your pc off and open the box to see if you can see the cable so you can connect it.
Posted on Sep 01, 2008
How do I get the cd/dvd player into the slots that are blocked
The plastic front panel will have removeable plastic panels the size of the CD/DVD drive, these are held in place by clips, you can push the panel out.
You can also remove plastic front panel, it may be secured by screws or plastic clips. When you remove the plastic front panel the CD/DVD drive slot may be covered with a metal plate, you can remove this plate by bending the metal plate back and forth until it breaks away from the drive bay.
Jan 22, 2012 | XION (XON-001) ATX Mid-Tower Case
JUST bought a xion amp solaris pc case and can't figure out how to get the front panel off
At a guess, you'll have to take one side off then look inside, behind the front panel, look for sprung plastic lugs at the bottom, middle and top of the case.
The front may be hooked in one side so there will only be clips for the other.
Sep 12, 2010 | XION Solaris (XON-409) ATX Mid-Tower Case
Replacement Door for XION case
Contact support to see if they will give you a replacement, if not, you can check e-bay to see if they have spare parts otherwise you might just need to buy a whole new case.
Dec 17, 2009 | XION II Black Pearl ATX Mid-Tower Case
Service AWd light is on on my 98 olds bravada
i got a 98 bravada and my AWD light was on, what i did to fix it was replace the transfer case motor and thats all, i did a bunch of research and found out that the transfer case motor is the main conponent with of your AWD it tells the transfer case when to give the front wheels power. try replacing that
Mar 16, 2009 | 2000 Oldsmobile Bravada
How do you hook in the front usb plugs into a asus motherboard?
You need a separate cable, called a USB header. It plugs to the connector in the case and onto your motherboard. A lot harder to find that you would think too, my top ports still are not hooked up after several years.
Jan 18, 2009 | XION _ Solaris XON-407 ATX Mid-Tower Case
XION Case and Supply
Try unplugging, then plugging back in the 20/24pin power connector. When you plug in the power connector, make sure the power supply is OFF and the switch in the back is OFF and nothing is plugged into the computer.
Jul 21, 2008 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
Power on Problem!!
Did you plug the cables for the front devices and buttons into the motherboard at the right locations? Are the polarities correct on for your cables?
Jun 26, 2007 | XION Onyx (XON-301P) ATX Case
XION Onyx (XON-301P) ATX Case Logo
147 people viewed this question
Top XION Computers & Internet Experts
Jax Planet
Jax Planet
Farokh Merek
Farokh Merek
JonSnell Electronic
JonSnell Electronic
Are you a XION Computer and Internet Expert? Answer questions, earn points and help others
