Coleman RV Air Conditioner Won?t Run.
I have a Coleman AC unit ( Model# 6759A707 Serial# 068404495) for my RV. It would get cool but quit running. So I purchased a start and a run capacitor for the unit. When I first installed the capacitors the motor ran fine but then unit would not get cool. I switched the capacitors thinking that was the problem but it would not run at all. This is still the case even after I switched them back. Does anyone have a wiring diagram or other service information for this unit?
5 Suggested Answers
  • 161 Answers
SOURCE: RV A/C fan won't start on its own
This could be the problem. It is more likely that the motor bearing is bad. Take the fan capacitor and have it tested. Or replace it, (under $20). Was the fan motor loud before this happened? Hopefully it is just the capacitor, the motor runs $60 - $100 and is a FUN to replace.
Posted on Jul 04, 2008
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 400 Answers
SOURCE: Dometic Duo-Therm - 13,500 B.T.U. Model #3107541.009 - Serial # WA346967 - Yr. 1999-2000. Blower motor will not start. Replaced the start capacitor - no help. It will run by spinning the motor by hand
Yes you should try replacing the run capacitor.
Posted on May 08, 2009
  • 82 Answers
SOURCE: coleman tsr rv air conditioner leaks into rv when running
It probably has a clogged condensate drain. Take off the cover on top the RV and check hoses or tubes leaving unit for debris or lint. Often this water is used to help cool the condenser so look for leaves pine needles etc in the pan. There may be a cover you can remove on the evaporator section that will allow you to clean the collection pan and hose or trough. Is it possible the RV is far enough out of level that the condensate can't "run uphill"? Always power off while working on this unit unless you are electric savvy. Good luck!
Posted on Jun 28, 2009
shastalaker7
  • 1515 Answers
SOURCE: Mach III Air Conditioner: i have a coleman mach I rv air conditioner. Last ...
Hi, its very possible the capacitor is open or shorted. Look it over to see if it is leaking oil or swollen or even deformed. When installing a new condenser fan motor, they should sell you a new run cap with it. Its probably a 5 uf 370 volt cap and you can have it checked to see if its putting out the right amount of micro farads. If it shows any of the signs I have said, the cap is bad and you will need a new one. Does the motor spin free? If you have a meter, a digital is best, you can check to see if the motor is open or shorted to ground. Set the meter on continuity, and check each lead to ground. If it is open, your meter will show no reading. If shorted to grd, you will have a reading or a beep if your meter has that option on it. This is how you will know. If it would be best for you to take off the run cap and take it in, they can check it for you where you bought the motor. Its not unusual to loose a motor in a year as they work hard in the heat. I have seen them last for years and for just a couple of months. Keep me posted.
Best of luck to you,
Shastalaker7
Posted on May 22, 2010
Mitsubishi slit air conditioner model MSZ-GA80VA I turn on and turn off cauting out door unit fuse blown I replaced still The fuse is blow is the out door air con unit Note.unit in door stop not inpos
turn off everything electrical in house and retry with good fuse or breaker if still blows unit needs repair possible shorted capacitor? if it runs it may need to be on its own circuit dedicated to it alone
Jan 05, 2017 | Mitsubishi Heating & Cooling
Cooloing is not coming down from room temperature
The unit needs service. Call a technician! You can:
Check your air filters
Clean outdoor coil by turning off all power at breakers and tstat, clean o.d. coil with water hose
Inspect indoor coil (if you can) for build up or debris
Other than that? May be low on freon. A service tech will cost $ BUT not having the unit service will cost more due to electrical consumption and excessive run times shortening the life of the system.
Jun 24, 2015 | Heating & Cooling
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Why does home central air conditioner will only cool to 80 degrees?
Because it is low on Freon. Do not run it low or the compressor wont be able to cool and you will burn it up. If it has run more than 1 hour in 90 degree heat the compressor is probably already damaged. Have a HVAC professional look at it, but if you were still using id plan for the worse, a complete replacement.
Jun 29, 2014 | Heating & Cooling
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Nov 28, 2013 | Heating & Cooling
Heat will not blow hot air model #310aavo48090oabjd serial #0205a42429
give name make of unit and set up of system oil/gas ect...
Oct 28, 2012 | Heating & Cooling
Water dropping on air conditioner
Water is dripping on your ac from a duct? Or is the unit it self leaking Are you sure you don't need a Professional Air Duct Inspection?
If you are in the market for an Air Duct cleaning check out Air Duct Cleaning Dallas Tx.
Jun 10, 2012 | Heating & Cooling
Heating & Cooling Logo
375 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
