Samsung LCD TV LN-4081F sometimes will not keep scanned in channels. It primarily losses digital channels. TV is directly connected to cable (no cable box).
How about helping me for free as your site implied?
Posted on Sep 03, 2008
Samsung LN-S2341W Picture Is Black and White
color circuit is out, try banging the set on the frame with the palm of your hand to see if color comes on or fluctuates, if so you have a loose component which is only fixable by you if you are really knowledgeable about the inside of a TV
Apr 28, 2017 | Samsung LN-S2341W 23 in. HDTV-Ready LCD...
I recently got a basic cable plan but am only getting a couple of channels.. How can I change this?
The best thing to do is contact the cable provider and ask them to provide a list of the channels you are suppose to get. With all the channel mapping and digital TV display devices these days, you might need to have your display device scan for channels if the signal is not tuned through the cable box itself. The channels may be there but the tuner in the TV device has not scanned the channels to register them into it's memory. Also make sure to set the TV for a Cable mode of tuner.
Aug 09, 2012 | Samsung LN-T3753H TV
My tv will scan and receive channels on a antenna but will not pick up channels on a cable scan with a good cable and a proven good cable signal
if you are not using a cable box and trying to connect cable directly to tv you will get very few channels since they are all digital now and most are scrambled
you will need to hook that cable to the input labled 'QAM' and program tv for digital channels
if you are coming out of a 'cable box' you just need to hook up video cables to an input on tv and change tv to that input - no scanning necessary
hope this helps - if not write back with more details and i will try to help more
good luck!
Mar 25, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I can watch movies on my samsung LNT3242HX/XAA but I am unable to see or hear anything if i hook it up to cable, i know something needs to be replaced but not sure what? the tuner maybe?? ;p
1. Make sure you have connected the cable to the correct input on the set.
2. Access the User Menu and do a "Scan for DIGITAL" channels.
That should do it...
Jun 13, 2010 | Samsung LN-T4065F Television
The channels won't work.
you can use another TV to test the cable.
Apr 30, 2010 | Samsung LN-R409D 40 in. LCD Television
Samsung ln-t4661f 46 inch lcd tv top 25 percent has faint lines going across please give answer to this problem
as i knew from my friend there is part called C1 OR C2
it is scan board connected from screen module from one side and then other side ether direct to power supply or to main analog board that got signal from main digital video board, that is what i knew.good luck search this on eBay or get other opinion.
Apr 28, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Can't get HD cable channels on Samsung TV
Have you check with the cable company to make sure they are broadcasting to you in HD ?
It takes more bandwith so some cable companies will charge extra for it so you will have to check.
Apr 17, 2010 | Samsung LN-S2651D 26 in. LCD Television
How do I turn on the digital tuner? Samsung
Hi my name is Roety,
I can help you with your issue ,
The digital tuner is always on, you just need to run the autoprogram in the setup menu with a digital signal connected.
An antenna is ant or air signal
using Cable click cable when scanning in channels.
If using a cable box there is no need to scan channels.
if using an indoor antenna it may not pickup any (roof antenna is better)
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
LN-R460D 46in, channels intermingled
are you using digital or terrestrial transmission? try fine tuning it...and hey, check the antenna direction, and also the wires...if the sockets are tight enuf and are correctly connected.
May 18, 2008 | Samsung LN-R460D 46 in. LCD Television
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
