Question about Sony CDX-M610 CD Player
Sony cdx-m610 BIG PROBLEM
HI. my cd player is stuck open and is stuck at one volume. no buttons work, but if you put a cd in it will play it. It will only play it from beginning to end, will not skip songs or adjust volume or go to radio. my email is uncle_ricko@hotmail.com. i believe i could be instructed in repairing it. thanks so much.
  • 1 more comment
  • Anonymous Oct 08, 2008
    My sony cdx-m610 stucked in one volume, it does not change volume neither by control or by manual. To play a disc i have to change mode several times. and when i change modes it take the volume that was left.
  • Anonymous Oct 15, 2008
    I have the same exact problem my stero will play a cd however I cant adjust the volume or anything else nothing works at all.
  • saint843 Dec 02, 2008
    my cdx-m610 is stuck open and no buttons work
    Problem Solver:
  • 13 Answers
Yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
Posted on May 06, 2009
    Problem Solver:
Just wanted to add that even though this person had this problem a while back the ribbon cable is no longer being produced by sony anymore. I dont know if the cable can still be found anywhere, but its a very common problem that people have with these units. The cd player is also no longer being produced either. Im having an issue now with the door not wanting to open and I lost a screw to it also. Jsut wanted to throw that out there. There 6 CD changer CDx T69 sucks though.
Posted on Nov 17, 2010
    Problem Solver:
  • 3 Answers
Replace Brown Flex Ribbon Cable, which is connected between Display and Main unit. this is a common problem, cable gets cracked as it moves with the display. Teknofix
Posted on Mar 07, 2009
My Sony CDX-M610 will play radio but not CDs
THE CDX-M610 LIKE ALL OF THE CDX-M630, M800, M850MP SHOULD ALL SIMPLY START TO PLAY THE CD WHEN INSERTED. BECAUSE YOU ARE ABLE TO TUNE RADIO STATIONS AND HEAR THEM PLAY SHOWS THAT YOU HAVE EVERYTHING IN PLACE AND ARE DOING EVERYTHING RIGHT. SO IF IT IS NOT PLAYING, THEN IT WILL NEED TO BE SERVICED. AS FOR THE REMOTE, IT IS NOT REQUIRED OF ANY OF THE CD PLAYERS IN ORDER TO PLAY CD OR TUNE RADIO STATIONS. RATHER THAN INVEST IN REPAIRING, I WOULD LOOK FOR ANOTHER MODEL ON EBAY USED AS IT WILL PROBABLY GO PRETTY CHEAP. ALSO HAVE CHANCE TO GET A HIGHER MODEL LIKE THE ONES I MENTIONED ABOVE. I HAVE SEVERAL OF EACH IN MY COLLECTION AND THERE ARE NICE PLAYERS. OK. HOPE THIS HELPS.....V
Jan 04, 2017 | Sony CDX-M610 CD Player
Mother board and lens repaire if the player is not respondin
HI,
PLEASE GO TO THE GIVEN LINK ,HERE U CAN GET FULL GUIDELINE ABOUT THE CD PLAYER.HOPE YOU CAN REPAIRE BY ALL THE HELP OF THE GIVEN DIAGRAM AND OTHER HELP. THE LINK IS :-
http://www.ps2netdrivers.net/cd.player/sony.cdx-m610/
I HOPE THIS WILL BE HELPFULL TO YOU.
PLEASE DON,T FORGET TO VOTE ME.
GOODLUCK.................
Jan 22, 2011 | Sony CDX-M610 CD Player
None of the buttons on my cd player work. I can put a cd in it and it will play it, but nothing comes up on the face and i can not change the volume
in your manual it says when you buttons dont function press the reset button
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=CDXM610PDF&sliceId=pdfPage_1&docTypeID=DT_MANUAL_1_1&dialogID=178426004&stateId=0 0 188734284
here is the link and it goes to sony scan down to troubleshooting and you will see were it says to press the reset for you problem
caraudioquestion@gmail.com
Oct 16, 2010 | Sony CDX-M610 CD Player
Sony xplod am/fm cd model cdx-m610 will play cds but the radio want play. i have tried to reset radio still will not play
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
May 21, 2010 | Sony CDX-M610 CD Player
I lost code for my sony cdx-m610 head unit
My M610 has a code try - off, source, att, openclose on the remote.
Apr 01, 2010 | Sony CDX-M610 CD Player
Sony Xplod CDX-M610 has blank faceplate
It sound like it has jammed in the mechanism, try pressing the reset button on the back plate, if this dont work you may need to remove the radio or fuse otherwise it may flatten your battery.
Dan.
Nov 24, 2009 | Sony CDX-M610 CD Player
Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Thankyou
Aug 10, 2008 | Sony CDX-M610 CD Player
Sony cdx m610 car stereo
sound - mode - att - open/close
pres buttons buy this order.
Aug 08, 2008 | Sony CDX-M610 CD Player
NEED THE CODE
contact the dealer where you bought your cdx-m610...then ask for the radio code...:)
Oct 17, 2007 | Sony CDX-M610 CD Player
Sony cdx-m610
Hello, there is a special decoding procedure. Please contact me at LIVE Expert Assistance. Best regards, Arpi
Jun 23, 2007 | Sony CDX-M610 CD Player
Sony CDX-M610 CD Player Logo
583 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
