Question about Sony Cyber-Shot DSC-S75 Digital Camera
Help w/ Sony DSC-S75
I've had this camera for a few years now and I haven't had any problems w/it thus far until a few weeks ago. I was plugging in the charger cable into the camera and pressed the On/Off switch at the same time!! When I attempt to power it back on, the green status light just either blinks or remains solid. The display screen does not appear and the camera does not function. I think it might be a battery problem.. however, I wanted to see if anyone here could help me out. Thanks.
    Master:
  • 551 Answers
If this is your original battery, I believe that it is time to replace it. I had the same battery in my old S85, then my old 707. It finally wore out, with very similar symptoms. Go on Ebay and find an OEM replacement. Don't buy an aftermarket battery for your S75. Buy cheap, buy twice. That S75 is still a great digicam. Replace the battery and continue to enjoy it.
Posted on Sep 11, 2005
SOURCE:
I have a Sony DSC-S75 camera and I am having a problem finding a memory stick are any of the SDHC cards compatible/
The only memory card you can use are the Sony Memory Sticks. You cannot use a Sony Memory Stick Pro, so you have to find one that is under 512MB capacity and does NOT say "Pro" on it. You cannot use any other format memory card such as SD or SDHC.
Thomas
Sep 07, 2011 | Sony Cyber-Shot DSC-S75 Digital Camera
Memory card error for sony dsc-s75 camera will not accept memory card
Format the card in the camera. Download any pictures still on the care first using a cardreader if necessary.
Aug 12, 2009 | Sony Cyber-Shot DSC-S75 Digital Camera
Help!
This problem is not related to plugging your camera into your computer. This is a symptom we have seen many times with various Sony cameras over several years of production. As far as we have been able to determine it is a problem with the sensor that feeds back the position of the zoom motor. I had a camera just a few days ago with this exact same issue. I swapped out the controller board and it did not change the behavior at all. I would suggest either sending the camera to a repair facility, or returning it to the manufacturer for service if you wish to get it repaired. The resolution will probably involve replacement of the set of sensors that feed-back the lens position to the control board. This issue is a problem with most Sony cameras, and as I said we have seen it several times and have not yet been able to identify the source. We forward cameras with this behavior on to Sony for service. David Millier Advance Camera Repair
Feb 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Dsc-s75 capacity
The 85 and 717 were the first cams able to use a contigous 256Mb Pro stick as far as I know, the 707 and 75 are stuck with the originals or the Switchable ones which defeat the object as if you've gotta pull it to switch "halves" you may as well take 2 normal and cheaper sticks along..
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
DSC-S75 focusing problems...
Without seeing a photo, here are a few possibilities. 1) Shutter speed too low (camera shake). 2) Camera is focusing on something in the foreground. 3) Focus not locked, low light, low contrast scene. Items 2 and 3 can be corrected by manual focus. Set the focus to 1 click below infinity, depth of field will insure everything is in focus. For item 1 remember that the shutter speed must be 1/125 sec or faster at full zoom to avoid camera shake.
S75 Battery Shelf Life?
It should easily last a few days. I didn't think the infolithium batteries lost its charge, but I could be wrong.
S75: which battery???
Please note that the webpage has been updated to reflect the proper battery to be used for the Sony Cyber-shot DSC-S75. Links work properly, now. http://www.sonystyle.com/digitalimaging/cybershot.htm
Sony Cyber-Shot DSC-S75 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
