Question about Konica Minolta magicolor 2400 Laser Printer
Multiple page printing.
I can only print 1 page at a time. If I need multiples pages of the same thing, I get an error and I have to shut it down and restart it.
Is this in every application?
When I have seen this before it can be that you need to tick / untick the collate box int he printing preferences.
Posted on Sep 16, 2008
How do I set my Brother NFC 665-CW to print multiple pages?
do u mean the whole multi-page doc or multiple copies of the same page?
the former would be what u tell it to print (whole document vs current page). The latter would be in the printer properties config page.
Sep 21, 2014 | Brother MFC-665CW All-In-One InkJet...
Tip
Printing Sections in Microsoft Word
Printing Word Documents with Multiple Sections You have a document with multiple sections. When you try to print specific pages, you get either one single page, or the whole document. What you don’t get is the two separate pages you need.
First, take note of which section has the first page you want to print, and in which section the second page resides.
You need to print Page 2 of Section 1 and Page 1 of Section two.
In this particular case, the command is the usual: File | Print:
The difference in this case is how you specify the pages to be printed. In the Pages dialog box, type P2S1, P1S2 and then click OK. The comma “,” separating the two pages indicates two separate pages. The result will print Page 2 of Section 1 and Page 1 of Section 2.
If, however, you wanted to print from Page 2 of Section 1 through and including Page 1 of Section 2, the command would be P2S1-P1S2. The dash "-" indicates a range of pages, which results in printing from Page 2 of Section 1 through and including Page 1 of Section 2.
on Mar 26, 2010 | Microsoft Word 2003 for PC
I have an HP LaserJet1020 printer. When I try to print a document a 2 inch wide area the full length of the page on the right side of the page) will not print. If I change to landscape printing, the same...
Run the 1/2 print test.
Print a few pages that have failed previously and as the printer is printing open the cartridge cover(top cover).
Pull out the cartridge and look at the paper down below. If the page looks good, you probably need a new fuser. If the page is messed up you could have a bad transfer roller or another bad toner cartridge.
Dec 19, 2010 | HP Office Equipment & Supplies
MY printer stopped working from on day to the next...the problem is when I print out a photo from IPhoto or Preview on my IMac OSX10.4.11 it starts with a large margin which doesn't allow for the complete...
Hello
Large photos are printed differently than regular photos.
Photos that have large resolutions or are best when printed in larger sizes are sometimes printed on multiple pages. Printing the photo on two or more pages requires setting up the printing options so that the printer recognizes how the photo should print and which areas to stop printing on each page.
Open the photo in iphoto
Select "File" and scroll down the list until reaching "Print". Click on "Print" and wait for the printing set up options. Some programs require selecting "Set up" or "Print set up" instead of "Print." Make sure the set up options are brought up according to the program.
Select "Time Imageable Table" or similar options in the program. If there is not an option with a similar title, look over the various titles and any pictures that come with the titles and see if the pictures show multiple pages or only a single page. Click on the options that allow printing one photo on multiple pages.
Select overlap options, which give margins so that connecting the pages forms the picture. Overlap around 1/2 inch or so.
Print the photo. The number of pages should match the set up options selected under the imageable table.
Nov 17, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
My Hp PRINTER just started printing 1 page on to multiple pages ?
check paper size settings on both your pc and printer manu.
Sep 30, 2009 | HP Office Equipment & Supplies
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Feb 29, 2008 | HP LaserJet 5550dtn Printer
Hp LaserJet 5 si
Check the print processor settings in the advanced tab of the printer properties. This should be set to Winprint, and not anything else.
May 01, 2007 | HP LaserJet 5si Printer
Konica Minolta magicolor 2400 Laser Printer Logo
135 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
