Question about Sony Cyber-Shot DSC-F717 Digital Camera
I put my battery into a digipower slide battery charger and it's not charging! I am seeing a red AND a green light blinking...what's going on?
  • 43,501 Answers
The red and green flashing lights indicates that there is an internal problem in the battery...remove and retry.... if it persists then the battery will need to be replaced...
heatman101
Posted on Jul 26, 2011
SOURCE:
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
Digipower tc-5000 does not charge 7.4V Li-ion for Lumix fz 47
In that case, you are not using the correct charger for the battery, which could cause it to explode.
Dec 09, 2013 | Digipower Cameras
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
I have a digipower lithium power charger TC-U100 and cannot get my Casio NP-60 battery to charge in it. Am I inserting it wrong?
Maybe. This unit charges all different kinds of batteries, but that requires you to make sure that you have set the prongs in the right position to connect with the particular battery you are charging. You move two pins to align with the outer contacts on your battery (not the middle one) and then a spring door holds the battery against them. The unit sets the polarity automatically. 4 lights blink green until the battery is fully charged at 4 solid lights, i.e. 1 blinking light is a quarter charged.
Nov 22, 2010 | Mizco Digipower Lithium Ion Digital Camera...
Im trying to charge my sony np-bg1 battery with the digipower travel charger. from my understanding, in the user guide it says that when a battery is charging the light will be red. well i have the battery...
I recently purchased the same exact charger for the same exact battery....I had to slide the battery in backwards to align the positive and negative and then it should charge properly. If you slide it in the other way which seems to be the front side of the battery the light will automatically appear green same as if no battery was in the charger. This is because its not aligned to the positive and negative from the battery to the charger. Best Wishes!
Sep 01, 2010 | Digipower Travel Charger for Select Sony...
My digipower travel charger flashs red when the
For mulitply camera battery charger ,there are many special online shop for you to select on the internet.
May 17, 2010 | Digipower Travel Charger for Select...
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Sony Cyber-Shot DSC-F717 Digital Camera Logo
375 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
