when I switch the machine on it does not automatically go to previous programme as it used to. I select the programmes, temp spin etc, the start light flashes but nothing happens when pressed. If I do this with the door open it repeats the click noise that it usually makes once before beginning to fill. It is cold water feed only and the pressure is fine and the pipe is clear. The light on the right for the water fill symbol does not illuminat. It did once after I checked the pipe but hasn't since. I have almost all the spare parts for the machine but do not know which bit may need replacing. Help!
Hi, I have a fault with the above mahine: when switched on the drainpump runs for about 10 seconds...
(More)
Hi, I have a fault with the above mahine: when switched on the drainpump runs for about 10 seconds and then it stops with the start/pause button flashing. It does this on every program and doesn't show an error code. Thanks in advance.
when i put the washing machine on a cycle half way thorught the cycle the lights will go out, and...
(More)
when i put the washing machine on a cycle half way thorught the cycle the lights will go out, and the wash will stop untill i press the pause button twice then it will go again. This will happen about four times during one cycle. I know this sounds silly but do you thin k i need to geyt a new washing machine? I have had this one for about 7 yrs.
start cyle, it makes a noise and then no water loads and it does nothing, checked all filters and...
(More)
start cyle, it makes a noise and then no water loads and it does nothing, checked all filters and water is going in to machine Tks
I need to replace the drum bearing but can not relese the star screw. We used hammer screw driver...
(More)
I need to replace the drum bearing but can not relese the star screw. We used hammer screw driver but doesn,t work. I have drum photo picture suppose sent to you, to what address? Thank you in advance. Best Regards Eddy Empu No 43 Karawaci - Tangerang Indonesia. Email : eddypras@telkom.net
