Question about LG Cell Phones
Need a manual for setting up my new phone.The piece of paper that came with the phone is very limited in what it covers!
    Problem Solver:
  • 6 Answers
Http://www.lge.com/support/manual.jsp
Try going to this website and see if you can download the manual for your type of phone.
Posted on Aug 30, 2008
Paper jam
From the reference manual for your Photo Printer
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=60202&prodoid=58654761
"Epson Stylus Photo R220 Series Printers"
The Paper Jams
Press the font29.gif paper button to eject the jammed paper. If the error does not clear, turn the printer off, open the printer cover and the CD/DVD guide. Remove all of the paper inside, including any torn pieces, then close the CD/DVD guide. Reload the paper, then press the font29.gif paper button to resume printing.
r_note.gif Note: r_space.gif If you cannot remove a foreign object easily by yourself, do not use force and do not disassemble the printer. Call Epson for assistance.
If your paper jams frequently, check the following:
  • The paper is smooth, not curled or wrinkled.
  • The paper is of high quality.
  • The printable side of the paper is face up in the sheet feeder.
  • The paper stack was fanned before loading.
  • The paper is not loaded above the triangular load-limit mark on the left edge guide.
  • The paper stack fits under the tabs inside the edge guides.
  • The number of sheets in the paper stack does not exceed the limit specified for that media.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Small piece of paper in printer resulting in PAPER JAM message. Cannot see the piece - what to do?
open back cover if you see rubber roller try to manually turn and check also paper sensor if no stock of paper.
Apr 13, 2010 | Brother MFC-465CN InkJet Printer
PAPER LIGHT FLASHING RED BUT MACHINE HAS PAPER IN IT
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 07, 2010 | Brother HL-2040 Laser Printer
Samsung Gravity Shuts Off Randomly
This only worked as long as I shut the keyboard gently. The problem really seems to be mechanical. When sliding shut, the battery is jostled just enough to lose contact and shut the phone down. Placing a folded piece of paper between the battery and the non contact side of the phone to increase pressure slightly.
Hope this works for you as well
Jul 18, 2009 | Samsung Gravity SGH-T459 Cell Phone
Manual for a T-Mobile,Sidekick 3,
Here is the link to the manual
http://support.t-mobile.com/knowbase/root/public/tm30131.pdf?&A2L.SERVICE=Manual
To fix the back cover removed issue, take a piece of folded up paper and stick it between the battery and the back cover. This will keep the battery seated.
May 04, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Lexmark x5470 paper sensor came out............
I have the same printer and yes that little piece limits the amount of paper fed in the printer. Repair manual? No there is no repair manual if you choose to do it yourself you may void the warranty.
Apr 21, 2009 | Lexmark X5470 All-In-One InkJet Printer
Set paper again/toner again error message
I had this problems and did everything suggested on here. Installed firmware update (which just changed the error message - didn't get rid of it), removed paper, changed size, replaced paper, tried new cartridge. Nothing worked. Finally found a tiny piece of paper that must have been blocking the sensor. It was on the left side near where the power cable is. It was less than an inch square. Got it out with some tweezers and problem solved.
Oct 17, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Piece of paper 1 inch by 2 inches jammmed and won't eject when I touch start button. I can't even see it with the cover open.
you have to open up your printer covers to extract that jammed paper. However, if you haven't tried tinkering with anything electronic before you will have to seek technical assistance from a qualified expert, but if you're willing and determined to extract that piece of paper, i suggest first you unplug any power connection from your printer, then unscrew the visible screws of the cover which is nearest the jammed piece of paper. never turn any cylinder if it resists your effort, however, try to manually turn cylinders where that small piece of paper is wedged until it comes off. Try to pull down on that piece of paper using a hair puller or forcep.
Apr 01, 2008 | Computers & Internet
OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I too kept getting the front cover paper jam despite followings Oki's paper jam removal instructions and blowing out the printer with compressed air.
In my case, the paper drawer was the problem.  When you pull out the drawer there is a spring loaded piece of white plastic at the very front of the drawer.  In the center of that is a gray rubber strip.  That strip had come loose in the center and bowed out, preventing paper from exiting the paper drawer.  I manually removed the strip, clipped off a little piece from one end so that it fit back in the recessed cavity on the white plastic piece and glued it back down.
This should be applicable to all Oki c5xxx color LED printers.
Dec 03, 2006 | OKI C5100n Laser Printer
Cell Phones Logo
23 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
