Question about KitchenAid KHWS01PWH Global Horizontal Axis Washer
Kitchen aid top loader washing machine does not spin
Kitchen aid top loader washing machine model #KAW5677EQO,the spin cycle was wearing out, needed to have heavy loads respun, then eventually stopped spinning and made a bad grating sound in the spin cycle. The machine is 10 yrs old, what is the fix, and the approximate cost?
  • 639 Answers
Peace Friend,
ngfam1 At your service!
Sounds like a belt problem!
Or the linkage connecting the transmission to the agitator.
Or the WORST THE TRANSMISSION IS GOING!
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
Simpson washing machine
More info would be helpful (model? top loader/ front loader?)
If it fills then stops filling (ie. knows that it is full) yet does not turn, and no sounds etc, it is likely a motor control module or motor start capacitor or maybe PCB (If fully electronic). Does it spin if you manually turn the cycle to the spin point?
May 27, 2014 | Washing Machines
Hallo,I have problem the cycle dosent spin kitchen-aid wash machine
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | KitchenAid KAWS850L Top Load Washer
Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Oct 01, 2009 | KitchenAid Washing Machines
Kitchen aide front loader washing machine won't finish cycle
On ours, i think that those codes were overload codes.. i had to go downstairs and turn the circuit breaker right off for about 5mins - when i clicked it back on, the washer reset.. i took some of the extra wet towels out and ran another wash with no issues..
good luck
tpug
Apr 27, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Machine does not complete washing cycles.
the lid switch must be working properly for it to spin.this is the area on most top loaders where theres a small hole and the actuator on the lid goes thru it and activates the lid switch .inspect this area for wear or damage
Dec 31, 2008 | Hotpoint Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer shakes on spin cycle
2 possible causes 1 cleanout filter and check water is pumping out properly before spinning
2 check the suspension legs at the base of the tub for wear or damage.
Oct 29, 2008 | Speed Queen AWS52NW Top Load Washer
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Loud clicking noise at spin cycle
It sounds like you have a motor coupling that has gone bad. Most of the Kenmore top loaders that I'm familiar with are direct drive machines. Which means, they use a motor coupling between the electric drive motor and transmission to run. If you are in the habit of doing heavy loads like comforters, blankets and jeans this can put a heavy burden on the motor coupler and wear it out faster. The coupler is designed to take the burden of the punishment in order to protect the transmission and drive motor and it is common for them to wear out. The coupler is fairly easy to replace and usually runs about $15. It is located inside the machine between the drive motor and transmission under the wash tub. You would have to remove the outside machine casing, the water pump and drive motor to get to it, though. Make sure the machine is unplugged before attempting any repairs involving removal of the drive motor. If you are not mechanically inclined, you may want to seek the aid of a repairman. I hope this helps.
Apr 29, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
306 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
